Loctite hysol 9462 source?
My Feedback: (60)
RE: Loctite hysol 9462 source?
Wow, I wouldn't call 9462 a generic, I'd call BVM's aeropoxy, 9462 with a fancy label Get your hysol at dreamworks and buy the gun at mcmaster.com do a search on RCU for "mcmaster" and author "seanreit" and you will find a list under a thread related to an expensive bolt. In that thread I list the part number for the gun at mcmaster for 20 bucks.
You can also find the gun on ebay for around 8 bucks if you look hard enough. It's a 50 ml epoxy gun.
Good Luck,
Sean
PS, I go through about 20 tubes a year of this stuff. It is a very good epoxy.
Good Luck,
Sean
My Feedback: (24)
ORIGINAL: seanreit
[snip]
Good Luck,
Sean
[snip]
Good Luck,
Sean
Bob
My Feedback: (24)
ORIGINAL: Countryboy
Bob,
Not to stray from the subject.... but did you ever finish your enlarged Ziroli Panther ?
Bob,
The structure is %80 finished, the P-120 is installed and the glass work is almost done. The last thing I was hung up on was making the sliding canopy, but I got some parts from BVM that they made for their big F-86 that will do the trick. As soon as I finish the F-100 I'm building for someone, I'll be back on the Panther.
Bob
#31
My Feedback: (31)
KY
ORIGINAL: sideshow
Anyone know what the shelf life of this stuff is?
Bob
Bob
#33
ORIGINAL: sideshow
I have looked for 9640F all over but can't find it. Has Loctite discontinued it? Does it have a new name? I gave my last two tubes to a club member and am looking for another source.....I guess I'll call Todd at dreamworks.......
Gordon
#35
Did you try Gluguru ? They still show it on their web-page, though that may be out of date. http://www.gluguru.com/Datamenu.htm
Only downside with Gluguru is that they require a $150 min order (or at least they did the last ime I put an order in - which was about a year ago).
Gordon
#36
My Feedback: (33)
HEY KEVIN!!
You still buying Hysol? I can use four cases, two of each, 9462 and 60. If not, that's ok, I'll try to find it here. I would suspect the price has gone up a few cents since your posting of the five buck price, that's to be expected, but not too much of a hike. If you don't want to fool with it (in case you don't have anyone to get in on the order) let me know that dealer and I'll order directly. I will also get enough in case some of your buds might just need a tube or two. Thank tons!
Don
teebox11
PS: I can pay directly to the dist. by any preferred method. Thanks again.
Please reply to me directly at: [email protected] as I don't come on here often.
Don
teebox11
#37
Zombie thread alert.......Last post 10 years ago, and "Kevin" hasn't posted since Jan 2012.....must be punking somebody.
#39
HEY KEVIN!!
Don
teebox11
Don
teebox11
#43
My Feedback: (38)
It seems a little thinner than 9462 but does not run. I have used it to wet out fiberglass cloth. Also have used with milled fiberglass and by itself. Working time is about 50 mins. I let it set overnight just like 9462. I haven't bought hysol since i started using it. What i like most is i can walk in the store and buy it. I don't use the mixing nozzel, i keep a few syringes on hand for tight spots. Cleans up with alcohol
