CROW FOR THE NEW 12X "Kingcat"
RE: CROW FOR THE NEW 12X "Kingcat"
Here is how I set up crow in the 12X. I gathered detailed instructions for the X9303 and they seem to work just fine in my 12X. Here's the link
http://www.rcuniverse.com/forum/fb.asp?m=6548167
I have seen some other people's set-up, but they were too confusing for me. The above works.
Good luck!
Good luck!
Send me an email to the address below and I will send you file for the 12X that works.
[email protected]
Dee
[email protected]
Dee
My Feedback: (39)
CA
Hello,
Question on the setup with the JR12X and using crow.
I have no problem getting everything setup, crow works perfect. My issue is when I use the ailerons in the crow. For example: crow deployed and lets say we add right aileron, the right aileron goes up even more driving way past what I have set in the travel adjust (ATV) so I end up with a lot of binding going on. Samething happens with left aileron. Bottom line is when I'm in crow I cant afford the aileron to go up any more. Any help/Ideas??
Steve
[email protected]
Steve
[email protected]
Its a piece of cake. Use the dual aileron function in the set up menu. Ail and Aux 4 or any available Aux channel. The 12x then labels the channels as Left Ail and Right Ail. Look at your code 12 menu. Then use a program mix make Flap as the master and you will see flprn as a choice for slave. Done deal. Now set up the amount of throw you need in the program mix. I do not have the 12x in front of me but it was just that easy. I did it on my Super Bandit using Aux 7. I used the mix switch to activate the crow.
