Flyeagle F18F
Reply
Old 05-25-2010, 11:01 AM
  #1626
salibaj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Flyeagle F18F
Hi,
When measuring the 25mm for the aileron, you do it from the tip or from the inner (towards the fuselage) of the aileron?
Regards
Joseph
salibaj is offline
Old 05-25-2010, 11:20 PM
  #1627
olnico
olnico's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: salibaj
Hi,
Regards
Joseph
Hi Joseph,
I assume that you are talking about aileron throw. In that case, 25 mm is way too much.
I am flying with +- 16 mm at the tip.
Elevator is 32 mm for pitch down, 47 mm for pitch up at the root.
Elevator offset for the flaps is very small ( 5 mm )
olnico is offline
Old 05-26-2010, 10:42 AM
  #1628
salibaj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Oliver,
Yes, I am referring to aileron throw. Thank you for your settings. You know that the aileron is narrow at the tip and goes wide towards the fuselage. Now, if you measure the tip you get a result, for example 16mm, but if you measure towards the fuselage it is more, because the aileron is wider there, am I correct?
I take it that you measure it at the tip (outside) of the wing.
As you refered to the elevator, from the root, I understand it from the inner part towards the fuselage, and the leading edge, as usually this was also mentioned to correct the neutral position of the elevator.
Thank you
Regards
Joseph
salibaj is offline
Old 05-26-2010, 11:49 AM
  #1629
olnico
olnico's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, you're all correct, Joseph.
olnico is offline
Old 05-30-2010, 11:36 AM
  #1630
alanjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nealy finished my f18 now, cheers olnico for the work u have put in on this thread didnt no it was u writing the articals in the jet mag keep up the good work
ID:	1445092   Click image for larger version
ID:	1445093   Click image for larger version
alanjets is offline
Old 05-30-2010, 11:41 AM
  #1631
olnico
olnico's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You're welcome Alan.
What takeoff weight do you get ?
olnico is offline
Old 05-30-2010, 12:07 PM
  #1632
alanjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I havnt done the c/g yet im hanging some scales in the garage in the week i will let u no then i weighed it last week before i put the engine and pipe in it was 28lb it had all the everything else in except batteries
alanjets is offline
Old 05-30-2010, 12:15 PM
  #1633
salibaj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Oli,
Have you ever put that article on how to balance the stabs please?
Alan,
I think your model is coming `light'! Congrat on the build
Regards
Joseph
salibaj is offline
Old 05-30-2010, 12:53 PM
  #1634
alanjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its a good job its come in light as its got a merlin 160 in. I have done nothing but read about balancing i no a few people now who have this plane some have and some havnt and they all fly nice but the forces that are applied to this control surface but big strain's on the servo. Its a mine field on this subject
alanjets is offline
Old 05-30-2010, 01:48 PM
  #1635
olnico
olnico's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: salibaj
Hi Oli,
Alan,
Regards
Joseph
Yes.
Have a look at RCJI.
olnico is offline
Old 05-31-2010, 11:09 AM
  #1636
salibaj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: olnico
Quote:
ORIGINAL: salibaj
Hi Oli,
Alan,
Regards
Joseph
Which RCJI issue?
Joseph
Yes.
salibaj is offline
Old 05-31-2010, 12:48 PM
  #1637
olnico
olnico's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The current one, page 48 to 51.
olnico is offline
Old 05-31-2010, 01:42 PM
  #1638
salibaj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Oli
salibaj is offline
Old 06-15-2010, 11:08 AM
  #1639
alanjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
could u tell me what servo's are being put on the ali plate for the steering
alanjets is offline
Old 06-29-2010, 12:00 PM
  #1640
alanjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
has anyone put any mixing ali/elivator on the f18
alanjets is offline
Old 06-29-2010, 12:52 PM
  #1641
olnico
olnico's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, keep it as simple as possible.
olnico is offline
Old 07-01-2010, 11:28 AM
  #1642
alanjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cheers oli im off to dubai the end of august for hols
alanjets is offline
Old 07-03-2010, 12:39 AM
  #1643
alanjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nealy ready for first flights just tryed the gear doors and gear some times one of the main gear bounces slightly off lock and causes the rest not to come down just what u want.Want it workin perfect before first flight i no i have seen it some were on here
alanjets is offline
Old 07-06-2010, 01:39 PM
  #1644
Henk Visser
Henk Visser's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Guy's
Want to show the Hawe gear for Fej F-18 1/7 and 1/6!
This gear is rock stable no more worries
for more info just pm!
ID:	1464084   Click image for larger version
Henk Visser is offline
Old 07-07-2010, 01:14 PM
  #1645
alanjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that hawe gear looks nice where was they made and do they have a website ? just done the c/g and it came out at 38.5lbs hope this merlin will power it ok
alanjets is offline
Old 07-07-2010, 02:24 PM
  #1646
Henk Visser
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: alanjets
Sure they have!
http://www.hawe-modellbau.de/english/
regards, Henk
Old 07-08-2010, 05:59 AM
  #1647
Slick 73
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check it out, my mate from xtremehobby.com.au has just finished the video from last weekend at the Jets over Fraser Coast in Maryborough Queensland Australia.
Its my new toy and just lov'in it.
www.youtube.com/watch
ID:	1464993   Click image for larger version
Slick 73 is offline
Old 07-09-2010, 02:53 AM
  #1648
olnico
olnico's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Guys,
I reorganized my ftp and that dropped some of the links to my pictures. So here is the tutorial about the flex plates with the pictures again, as requested by some of you.
I took the opportunity of changing them to make some pictures and do a small tutorial since I had so many questions about this concept.
First of all the flex plates consist of a series of carbon and plywood plates setup in layers without any gluing. This is important to get the most of the plywood characteristics ( shock absorbing capability ) and carbon fiber ( flexibility ).
On the F-18F I have, in sequence from the bottom to the top :
1 plywood plate of 3 mm ( the purpose of this one is to transmit the landing gear peak efforts to the carbon fiber plate without braking it )
1 carbon plate of 2 mm ( this one is providing the spring effect and flexibility of the assembly )
1 plywood plate of 6 mm ( absorbs the gear efforts and breaks in case of hard landing/huge loads, also holds the blind nuts)
On the following picture, the bottom plate is the thick one that comes to the top in the plane.
This composite plate shall not be glued to the formers neither because the damping effect comes form the layers being able to move relative to each other and relative to the formers.
Here is a view of the composite plate in my hands:
This as a consequence will enable you to fully service the gear from the bottom ( gear bays ) without having to remove the engine and saddle fuel tanks. This will save you a lot of time since the gear is the critical component on this jet and needs continuous maintenance.
Here how the plates shall be changed ( note that only the thick plate will brake in case of problems so cut a couple of them initially):
And the assembly back in position:
The plates hold in position because of the indent made at each end.
With this setup, I have to change the thick plate every 25 landings. This setup actually saves the whole structure from being damaged.
olnico is offline
Old 07-09-2010, 10:04 AM
  #1649
alanjets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oli have u done any articles in the next the jet mag ,just wandering if u had any air leeks on the gear door rams
alanjets is offline
Old 07-09-2010, 12:53 PM
  #1650
olnico
olnico's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes Alan, I've had my door rams leaking one after the other. I've changed them on condition with Airpower cylinders. Today I think that I only have one original ram left...
olnico is offline
Reply
Display Modes
