Build thread or Manual for FeiBao F-86 ?
My Feedback: (194)
Hello to all...:
I just purchased a Fei Bao F86. Should be receiving it in a couple of weeks. Is there a build thread with photos on this Plane from FB??? Or any Instruction Manual??'
Any Help would be greatly appreciated.
My Feedback: (60)
RE: Build thread or Manual for FeiBao F-86 ?
Get all the elevator that you can, CG is 1" forward from center of the strut.
If you've built a jet before, this is not a bad build at all, I did mine in about 3 or 4 days as I recall. No instructions other than what I've just said here.
My Feedback: (12)
CA
mine has been set up ready to fly for 6 months now, but fire season is bad here so no burning kero. but will be at Fresno jets in 9 days, maybe I'll finally get to fly it[sm=thumbs_up.gif]
ORIGINAL: fevifi
Seflyer...:
Was it easy to build???
Seflyer...:
My Feedback: (12)
CA
the speed brakes were the most challenging part of the build, and getting the outer gear doors to open with the gear was a little work. when I first looked at the insides of the jet it appeared to have a ton of room, that was until I put the intake duct in there, bye bye room. finished weight without fuel is about 24.5 pounds. power is a P-70, someone else fairly local has one with the same power and says it flies just fine. Kevin
ORIGINAL: fevifi
Wagner... Any news on the manual ????
Also.. Status of the F86...???
My Feedback: (194)
Here the photos of the plane as I just unpacked it...
I can say...: Excellent construction and very good paint finish...!!!!
Just waiting on Wagner to clarify for me some doubts.
My Feedback: (194)
Do not know... It came installed on the plane. Plane came assembled as shown in photos...!!!
Will take closer photos and post tonight.
thanks
thanks
My Feedback: (194)
I have been waiting for some one to help me...!!!!!!!
I have a couple of questions....
1) Because I have been waiting on an answer from Wagner now for 2 weeks on where do the elevator servos go installed,and NO answer or help was received, I proceeded and installed the DS168 Thin wing JR sevos inside the elevator... I mean.. the elevators did not came with any space or holes or marks on where do I was supposed to install the elevator servos....Did I do ok?? Or is there other way??
2) Is the CG of the plane 310mm from root leading edge??? Seems to far back to me...???
3)Can I leave the turbine installed WITHOUT installing the TOP black FRP cover supplied with the plane???
4) Servo travel on the Flaps and elevator throws???
5)Air Brakes...: Do I install a separate valve to them and operate them on a separate switch... or how do I proceed??? Do they go with the flaps on the same switch??? WHEN DO I OPERATE THEM???? (During landing aproach..or only as show off on runway??? IT IS THE FIRST TIME I BUILD AND OWN A PLANE WITH AIR BRAKES....
6) On the TURBINE exhaust.... should I leave any space between turbine exhaust and FRP black bottom cone/cover that came with the plane???? A photo will definetly help me.
7) Any tendencies or important info. I need to know before flying it???
Just in case my e-mail is: [email protected]
My Feedback: (14)
Felipe, check out this thread if the Spanish forum. I belive the elve. servos are installe ala SM one or similar way. The post have some fotos too that might help you. http://www.miliamperios.com/foro/vie...ht=fei+bai+f86
Saludos,
Alejandro
Saludos,
Alejandro
What scale bird did FeiBao used for their molds? The nose intake looks different than the ones I have seen. It looks more like a triangle. Maybe its just the angle of the picture. Does it look more rounded standing right in front of it?
