spark ignition for turbines
My Feedback: (7)
RE: spark ignition for turbines
WOW , the back channel response for my spark ignition system has been overwhelming. so I will be making it availlable , but no business done here, only back channel....
Thanks everyone...
Roger
Thanks everyone...
Roger
My Feedback: (7)
By the way , I hope to get a video here within the next few days if I can get my buddy to help with his camera,
By the way you can check the build thread of my Turbo prop Laser here
http://www.flyinggiants.com/forums/f...rop-build.html
Sorry guys its on Fly Gia , rcu won't let me post the link hmmmmm...
Roger
Roger
Just a short note on this subject:
As ecu manufacturer, we considered and tested the spark ignition some years ago to be included in the ecus. Ignition was OK, but the possibility that the high voltage could damage the electronic components in the ecu (happened during tests), forced us to reject the idea. For those who need a reliable glow plug ignition, we can offer a ceramic glow plug, very similar to the ones used in kerostart, but with a thinner element and less power. Compatible with ecus from software version 5.54 and up.
Gaspar
Please note that unauthorised modifications can invalidate your warranty on an engine - for example, Gaspar has said that the high voltage could cause damage to the ECU, and obviously neither Gaspar (as manufacturer of the ECU) nor Wren ( as manufacturer of the engine and retailer of the ECU) would cover you for this.
Sara Parish
Wren Turbines
Sara Parish
Wren Turbines
#31
My Feedback: (7)
You all bring good points and thanks for bring them up, but so far with my design, I have made 10 starts with no problem whatsoever, and the starts are quick and solid
I know you have to cover your ass, and I understand that...
Roger
Roger
#32
My Feedback: (7)
OK guys , you asked for it, you got it, the turbine spark ignition will be availlable within the next two to three weeks.
This will be a plug and play.
After over 20 starts , there has been no problem , and easily starts first shot...
Check my web site for pricing or contact me directly.
Roger
Roger
#33
My Feedback: (39)
With Kero Start becoming more and more prevalent with the added advantage of a single fuel, I would say your product idea has a very limited lifecycle.
In my experience, I use the 10% rule- ie, in reality, only 10%of those who express interest will actually buy.
PaulD
PaulD
#34
ORIGINAL: Forgues Research
Roger
Roger
Next time, just say "BUMP"
it's shorter...
#35
My Feedback: (7)
ORIGINAL: SinCityJets
it's shorter...
Roger
Roger
it's shorter...
BUMP??? hmmm and that would mean??
Roger
#36
My Feedback: (7)
ORIGINAL: PaulD
PaulD
PaulD
For those who know me, I develop things for my own need first . then if someone wants it, I will see if I can make it availlable.
I will test it for my own use, if it passes all test as I have done with my fiber optic servo extensions, then and only then will it be availlable.
So with this between my partner Hayes Hutchins and myself, we have enough turbines to use my first production run so its no problem.
A lot of propane start outhere ...
Roger
#38
My Feedback: (7)
ORIGINAL: i3dm
forgues-research, what would be the price of the unit ?
http://forgues-research.com
[email protected]
702 421 2925
Regards
Roger
#40
My Feedback: (7)
ORIGINAL: f16jc
Looks like a good product, good luck with it. Joe C!!
Thanks, as I said, as long as it works for me I'm a happy camper, but it won't make me the next millionaire on wall street LOLOLOL
Roger
#44
My Feedback: (7)
ORIGINAL: Moerig
Do the plug fit in standard glowplug hole?
Yes it does, its a direct replacement. It is plug and play, very simple... No modification to the turbine or to the ECU..
Roger
#45
My Feedback: (7)
As an update,
I have done more then 25 starts with the spark ignition with perfects starts everytime, and no problems whatsoever to the turbine, or to the ECU
I will start shipping within a week...
Thanks for all the support
Roger
Roger
#46
WOW...... no more burnt glow plugs. I want one
But the first turbine I bought is still on the original glow plug after
3 years flying & lots & lots of flights.
At just $5 a glow plug this idea makes no sense to me.
It sounds like you have a more expensive, more complicated replacement
for something that works perfectly anyway.
Like I said, good luck, but I will not be lining up to buy one. - John.
#47
My Feedback: (7)
ORIGINAL: Boomerang1
If you can sell some units good luck to you.
hahahahahaha, I didn't have you on my list of customers!!!! you are one of the lucky ones, hang on to your good luck glow plug, but many are changing plugs too often.
Roger
#49
My Feedback: (7)
ORIGINAL: rjbob
Have you had the opportunity to test it on several different turbines/ ECUs yet?
No I haven't but I am sending a few units to my buddy and co developper, Hayes Hutchins, in Alabama, he has Wren turbines and other makes also
but basically, they will all the work the same because of the way I have done this.
As I said , there are no modifications to either the ECU or the turbine aside from replacing the glow plug with the spark plug .
Roger
#50
My Feedback: (7)
Here is the spark ignition video I did for U tube.
So far 35 starts and everything still running to perfection.
http://www.youtube.com/watch?v=VGr8apHhZHo
Roger
Roger
