Jetcat P80 SE
RE: Jetcat P80 SE
ORIGINAL: raptorlogo
Hello,
What is the spool up time of the new P80 SE ?
What is the first serial number of the P80 SE line ?
Best regards
Hello,
Best regards
You'll find a complete engine review there with spool up time and other practical information as well as a complete benchmarking by Tom...
RE: Jetcat P80 SE
If you are lloking for a serial number to know whether a turbine is a P80SE, it has a different tail cone like the 60/120/160. It's slightly shorter than a P120
Dave Wilshere
Dave Wilshere
RE: Jetcat P80 SE
Hi Alain
I am flying two of the P-80 Se's now and cant give you exact technical figures on the spool up times from bench running, but I can tell you that in real life application ( Flying many flights ) The spool up is considerably faster than the older non Se P80. I compare it to a P-120 Spool up. Not quite as fast as the 160 series but much faster than the older P-80's. Also the increase in power is noticeable also. Regards Al
RE: Jetcat P80 SE
The P-80SE achieved considerably faster results in hot weather conditions than the P-160SX.
It is actually the fastest accelerating Jetcat engine I have tested so far in these conditions.
