RC Monster Trucks Discuss rc monster trucks in this forum
What kind of servos should I get for my CEN
Reply
Old 04-27-2004, 04:04 PM
bonified5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default What kind of servos should I get for my CEN
I have a cen mt2 and the steering and braking isnt too good. What kind of servos should I get or is there something else to get? I already have a metal disc brake. Thanks.
bonified5 is offline
Old 04-27-2004, 08:56 PM
nitromacguyver
nitromacguyver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: What kind of servos should I get for my CEN
for my steering servo i use a futaba S3305 metal gear servo. it is not abad deal at 35 dollars. i only use a standard servo for my throttle/brake but it works fine. are you still using the stock servos?
nitromacguyver is offline
Old 04-28-2004, 08:25 AM
slodsm
slodsm's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I prefer the 9402 for steering and 9405 for throttle/brake for my MT's and buggies. very fast and plenty of tq. Both Futaba as well.
slodsm is offline
Old 04-28-2004, 01:25 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use the stock high torque servos on my MT2 and have never noticed a problem with em.
mecky33 is offline
Old 04-28-2004, 03:32 PM
crazypyro013
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
a good cheap and prob most popular is the Hitec 645MG for the steering, then take the stock steering servo, and move it too throttle/brake control
crazypyro013 is offline
Old 04-28-2004, 03:34 PM
Element
Element's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use 2 hitech HS-645MG They work great
Element is offline
Old 04-28-2004, 05:55 PM
bonified5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok thanks and yes, i am using stock servos
Old 04-28-2004, 06:40 PM
bonified5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The problem that I am having with the throttle/brake servo is the trim is all the way down and if I put it in the middle, the car will move forward. If I put the idle down, it will stall. Not sure what to do. I know its not really the servos problem. WHat should I do? Also, if I got a new servo, would I have to get a new receiver?
Old 04-28-2004, 06:52 PM
crazypyro013
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
adjust your idle screw for one, the motor should never die
if that doesn't help you need to richen the mixture a little
Old 04-28-2004, 07:01 PM
bonified5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok thanks
Old 04-28-2004, 11:11 PM
mecky33
mecky33's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Before you mess with the idle, set your throttle trim to center with the engine off. Then pull the servo horn off and move it so that the carb is closed or most of the way closed, re install the servo horn. Then re adjust your brake so that it is full engaged when the brake is fully depressed. Then if this doesnt completely fix your idle problem, retune the engine.
mecky33 is offline
Old 04-29-2004, 04:47 PM
Sweetshoes90210
Sweetshoes90210's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RETUNE IT LAST! It makes a big differece.
Sweetshoes90210 is offline
Old 05-02-2004, 05:07 PM
Sweetshoes90210
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Haha. I never put what servos to use. I recommend 2 hitech HS-645MG servos. Supper fast resonce and alota torqe.
