Gears?
Gears?
Can you guys explain to me the major difference between high speed spur gears and low speed spur gears? And the difference between high speed pinion gears and low speed pinion gears?
RE: Gears?
its just the amount of teeth on the gear that changes the speed,more teeth on a spur gear and more low end torque less teeth and more speed i think not to sure about pinion i only ever change spur gear and im no genius at gear ratios
