Cant get it to idle.
OK I have a tower terror and I can get it to run if I give it a little throttle but if I let off it dies. Also the wheels roll when I hold it but when it is on the ground it does not roll. Is that what it is supposed to do? I am new this is my first truck please help.
WI
RE: Cant get it to idle.
Sounds like you just need to double-check your LSN and Carb settings. Yes, you will get different results when the truck is under "no load." That thing is something like 13-15lbs, so you have to overcome the weight when it's on the ground.
OK I fixed it the gears wear bound up. And that fixed the idle problem also. I just finished running my second tank through and the power is starting to show up. It is still sluggish in the low end though.
