Savage suspension sag?
Have you guys noticed how much the savage's suspension sags right out of the box? Do you think it'll hurt or help the handling if i tightened the springs with spacers so that it stands up higher when it's running?
You would definitely hurt the handling if you raised it up. Not only would it raise the center of gravity, you would stiffen the suspension and reduce its ability to absorb bumps. The Savage is the best handling truck there is, right out of the box. That being said, I doubt you would hurt it a whole bunch if you didn't stiffen it too much, and you could always change it back.
sage at when its hot out.
a buddy of mine has a savage. we took it out on a hoter day here in okc it was about 76 degrees and man the oil in the shocks sure got thin and they droped the truck about 1 to 1 1/2 inch, which i guess was good but not really couse he likes to play at the bmx track. gives the mt a realy beating out there.
I think the stock oil W is 30 w is it not???
Later.
Later.
CA
By adjusting the ride height on a truck all you are doing is adjusting the ride height. It does NOT affect the spring rate in any manner. The spring is going to respond the same whether the truck sits 2" of the ground or 5". Spring rate as well as oil determine how the rebound works and how the truck will handle.
My Feedback: (9)
I just ordered a set of 4 lbs springs for stock savage shocks. They say the stockers are like 2 lbs each.
I don't have an issue with the shocks, but maybe a higher spring rate might be nice.
$19.95 from New Era models. I also ordered the wheelie bar, so I can ride that wheelie
