-=OFFICIAL HPI FIRESTORM THREAD=-
#1476
RE: -=OFFICIAL HPI FIRESTORM THREAD=-
ISSUE NO 1: PRESSURE SPRING THAT SUPPORTS THE STARTING PIN:
= Ever since i bought this last Jan 1, 2008. I been changing this for 3 times already. Bought a ROTO START which I thought will fix the problem. Nope until now it always break. So Im planning now to go for starter box which will by-pass the piston rod starting method.
ISSUE NO 2: DIFFERENTIAL
= The item is only one month old and whalaaa. Does not pull anymore when doing full throttle. Opened the diffs and found out no grease was in it! Very dissapointing!
ISSUE NO. 3 CLUTCH SPRING
= 2 weeks old when bought it. Clutch spring broke. Thats the reason why i am having a hard time firing it up.
Ever since I bought this, I only played it 2x in a race track. Most of the time I'm fixing it.
Do I need to write a complaint letter to HPI? I don't get enough support from the exclusive distributor of HPI here in the Philippines. They just don't listen to me.
#1477
ORIGINAL: BrisbaneTNX
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPZD8&P=7]HPI Clutch BEll 21T[/link]
It's a direct replacement
As for the 21t, can anyone give me a link to what they are using in theirs? And is it jsut a direct replacement?
#1478
#1480
Hey,
So far managed to break my Firestorm twice, in one week! I've bent one of the rear axles (my wheel now wobbles slightly as it goes round) the axles are £8.99 a pair though (5x41mm) could I use the RS4 axle £1.32 (5x40mm)? Or would that one mm in length be a problem?
#1481
How often do you refill the diff? I've currently got Associated 30K in there but I'll probably step it down to 10K. I know it is sealed but I don't think it is absolutely air-tight. On my brushless "E-" I notice minor seepage around the output cups...the upside is that the tranny gears stay lubed, but overtime I think the diff will eventually run dry.
#1482
Does the "HPI clutch shoe set" effect the performance any???
#1483
CO
I put 50 weight in my diff and it turns it into a locking diff. You dont want to put to much on the diff because it is hard on the gears. It has worked great for months!!!!!!!!!!!!!!!11
#1484
I've bought 10 weight oil for when I need to top it up/strip it, do you think that'd be ok?
back to my previous question, would the rear axle from the RS4 fit even though its 1mm short?
#1485
My Feedback: (20)
IL
I know this has probibly been asked but Is there any aftermarket A Arms for the Firestorm?I finally finished breaking it in and notice alot of slop in front A arms.This has only been drove on my street for break in only.My rc10gt has very little compared to this and thats been beat.The firestorm hasn't even seen air yet.Any suggestions.
#1486
NY
Hello,
Just got my firestorm and was trying to break it in and it will not stay running for more than 30 seconds. I adjusted the idel screw and the high speed needle...what else could it be
#1489
CO
Return the needle setting to the orginal specs that are in the manual. Just put the idle screw just a little higher than org. specs.. Only do one thing at a time when breaking it in.
#1491
NY
ORIGINAL: will0983
NOW THE MOTOR STARTED TO SMOKE
Listen. Reset the high speed, low speed and idle screws.
Use the manual.
Start turning the low speed needle clockwise 1 hour increments (leaning it). Until it starts running better.
Then google or search here "nitro tuning" and read some more.
#1492
just ordered a load of hop ups for my firestorm, ally arms, graphite deck, shock covers, oil, diff oil, tyres, the works. I'll post pics up as soon as I have it all together in a week or two!
#1495
finally some graphite decks! Haven't seen one on a Firestorm yet but I couldn't resist getting one myself, only had it 2 weeks, and already spent too much on it! I promise I will stop now though...
#1496
what website do you guys order all of your hpi parts???? i have been looking around for updrades like that cabon fiber plate but i can find and websites that carry them.
#1497
You can get all the other Hops ups too from tower hobbies
#1498
I ordered mine from http://stores.ebay.co.uk/Mega-RC-War...18026569QQtZkm
Quite a bit cheaper, and compared to UK prices, a bargain! cost me just over £20 delivered, but is £35 in stores here!
#1500
PA
If you get moab 2.2s you will be pulling wheelies like no other!But with the right tune you can pull wheelies with the stock tires as well.
Try the pinch test to see if the low end is to rich.Pinch the fuel tube(Not the pressure tube)and if it takes 3 seconds or more 'till the engine shuts off,then you are to rich(on the low end)If the engine shuts off at 1-2 seconds,then you are about right.
After you did all that,you still should see a nice trail of smoke at take off.
