GT2 motor rebuild
RE: GT2 motor rebuild
ok and should i lock tight those screws as well.
and i took the head off and the piston has like a brown tint to the top of it, there is some dirt around the sleeve, and the inside of the sleeve looks ok but how do i check compression to make sure its wear it should be. here are some pictures and i video nither came out good but i tried
Pics are a little blurry. Push the piston into the sleeve. The piston should become tight within 1/8" - 1/4". If it slides through the sleeve the sleeve is toast. Otherwise put something flat over the sleeve and push the piston into the sleeve slowly, should feel if there's a leak.
P.S. The piston looks "smoked" on the video.
ok i seem to have fixed the problem but then it came back again and i noticed down by the carb. were the lowspeed mix screw is that whole assembly that turn to open the carb(the little black arm and the low speed screw) is comming loose but the thick back plate type black plstic is still attached. i tried to take a pic but no luck so if need more of a description i will come up with something in paint if you need me to.
thanks for all the help
skyler
skyler
#31
Sounds like your nut has come loose.The one opposite the throttle lever. Pull the carb off the car. Remove the HSN assembly. Make sure you don''t loose the crush washers. (2 of them). Insert a "clean" small allen wrench into the hole and it should go through the LSN assembly. Then tighten the nut up and use a little loctite(blue) If it doesn''t feel like it went in then you''ll need to rotate the spray bar assembly which then involves removing throttle lever and everything behind it. Go to RC10.com and look at a diagram of the carb. Hope this helps and good luck. I had the same problem and that''s where it was leaking.
P.S. If it's the nut on the throttle lever side simply tighten with a "little" loctite
#32
ok here is picture of my problem
ok so the green is the motor
1. the silver metal bar that is sticking out its not suppose to be
2. the plastic black arm that attaches to servo
3. LSN
4. gray nut on the lowspeed
5. the part that is still attach to the engine
3. LSN
#35
MN
Your paint diagram didn't do much to clarify anything. And the explanation from 1FastGT2 is a about as clear as it can get. You need to know what you are looking at before you can ask for help with the thingy that has a do-hickey sticking up over by the hefershafer.
There are diagrams, with part numbers and names, and exploded views showing assembly order, and step by step instructions in the owner's manual.
