RE: GT2 motor rebuild
ok i seem to have fixed the problem but then it came back again and i noticed down by the carb. were the lowspeed mix screw is that whole assembly that turn to open the carb(the little black arm and the low speed screw) is comming loose but the thick back plate type black plstic is still attached. i tried to take a pic but no luck so if need more of a description i will come up with something in paint if you need me to.
thanks for all the help
skyler
