Official RC10GT Thread
#1376
CA
RE: Official RC10GT Thread
integy makes a screw driver set for like 40 bucks, fits every screw on the gt, plus many many other cars,
your diff is to loose, i am having same problem right now, but i fixed it last night, check my other thread, gt diff prob
#1377
TX
ORIGINAL: GTdirtracer
#1378
SC
Most screws on the rc10gt are 1.5mm or 2mm. These wrenches strip out a lot, so you may want to keep some of them around. About you tire spinning problem...If yor diff nut is not tight or if it is broken it could cause that problem. It is only a 5 dollar fix, but it is a lot fo work. i would talk to the guy you got it frmo and find out what he has done to it.
#1379
TX
ORIGINAL: truax
I'll probably just buy the same Dynamite set of sockets and hex wrenches that my friend has, sometime when I'm feeling rich
#1380
PA
I am having a problem with the spur gear on my GT. It keeps stripping out, i dont think its the gear mesh. I recenty upgraded to a four shoe clutch and ive stripped 3 spurs inside of an hour. The slipper is losened all the way, so the only thing i can think of is getting a metal spur gear. Anyone have any ideas? or different ways to check gear mesh, other then the pice of paper between the clutch and the spur?
#1381
CA
i jst do it by feel but i have been messing with gts for a over 5 years,got pretty good at everything on it ecept the diff damn that thing is annoying
#1382
NY
what is a good racing motor? i was thinking [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXN386&P=7]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXN386&P=7[/link]
dose anybody have any sugjuestions? thanks alot
colin
colin
#1383
TX
Is it possible for my slipper nut to be coming out?? I'm running an OS 18, so it's got a lottt of power going through it. I think it's slowly coming loose again, and I don't have a socket that fits it. What's the cheapest socket set and cheapest hex set I can buy that will fit all the screws that are on it? I know I'll need a 1/4" socket and 1/16" hex... any ideas? CHEAP?
#1384
TX
I'm having the same problem still, but have determined it's NOT the slipper. It's now something inside the tranny... I've taken all the slipper stuff off, and I can hold the tires (CVD's not moving) and turn that shaft and it turns. So something inside the tranny case is messed up... I'm hopefully going out soon to get the hex/allen wrench that I need, and I'll be able to open it up.
#1385
TX
I fixed it!! It was a combination of the diff screw and the slipper nut. I need a new differential spring - I just realized tonight that I don't have one!! Maybe that will help the problem. I bought a Craftsman 1/16" ball hex driver and Craftsman 1/4" socket - now I think I have a tool for all the screws/nuts on the truck [8D]
#1387
TX
Does anyone know where to get alluminum parts like rear hub carrier/uprights, front c hubs, ect.
Carbon Fiber Shock Towers
JH Racing Alum. Tranny Brace
JH Racing Aluminum Brake Disc
Lunsford Punisher Titanium camber/toe links
MIP Shiny CVD's
Robinson Racing Top Shaft
Robinson Racing Steel Idler
Robinson Racing Aluminum Diff
RPM Bulkhead Center Link
RPM Rear Bulkhead
RPM Receiver Box
RPM Rear 0-Degree A-arm Mounts
Team Bluestar Alum. A-arms
Team Bluestar Alum. Steering
Team Bluestar Alum. Hubs
#1389
NY
colin
colin
#1390
TX
I'd say go with anything made by OS. The one you linked to doesn't look good to me... too expensive for a decent racing motor. Unless you wanna unload a whole bunch into the motor, then a whole bunch into reinforcing parts that will break, go with a ~$100 OS motor.
#1391
AZ
ORIGINAL: hanney
colin
colin
For a budget, OS.12 cv-r engine is great for the price. But if your willing to pay a bit more, I would recommend a NovaRossi .12.
#1392
CA
the motor you showed cant be raced legaly its a .15, are you really gonna race or just dink around, If your actually going to race i would suggest a picco.12 or a novarossi and if you go back no more than 3 pages there is a whole page of motors and links from me
#1394
TX
ORIGINAL: hanney
i think im going to just bash, ive herd of the os .18, i might get that but what do i need to do or get to make it run? yhanks
With mine, my friend and I just used the parts from the stocker motor (collet, some sort of small black flywheel, stock clutchbell and shoes, etc.) The only thing we had to do was cut the shaft to fit. I had the regular crankshaft length cuz I had originally bought the motor for my ST-15. So my friend just Dremeled it off, and it works great!! It bolted right on to the pullstart motor mount with no problems.
So.. if you're going to buy a new OS .18 (which I highly recommend), get this one http://www2.towerhobbies.com/cgi-bin...&I=LXGGP8&P=ML
#1395
NY
[link=http://www.rcuniverse.com/market/item.cfm?itemId=175191]http://www.rcuniverse.com/market/item.cfm?itemId=175191[/link] wow y is thet so cheep?, to bad i cant afford it at the moment, "i need a job"
#1396
CT
Hey all,
Im having a problem with my truck. I can not seem to get it started. When I plug the exhaust and pull on the starter cord a few times nothing really happens, the fuel just sits at the bottom of the fuel line and moves about 1/4 inch up the line and back down. It kind of sounds like an air leak just before it goes back down. I pulled the line off the carb and tried it again and out came the fuel very easily. I put the line back on the carb and pulled the line that goes in the pipe and blew into it. I could get it about half way up. I pulled on the throttle and at about 6/8 throttle the fuel moved into the carb with ease. I tried to start it and nothing. I can put fuel right into the carb and it will run for about a second and cut out. Does this sound like a plugged up carb? If so what can I do about it.
#1397
TX
First off, try the easiest thing: Replace all the fuel tubing and check all fuel tubing connections. If that doesn't fix it, then it's beyond my knowledge
#1399
what size engines will fit in the truck? is there certain models of motors that you cant use? right now i have the stock rtr .15 in it what gearing do you need to get the fron wheels off the ground?
#1400
TX
ORIGINAL: morefuninajeep
