Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
Reload this Page >
CA Model XURAMA BIPLANE Build Glow Powered
Old 11-12-2011, 07:25 PM
  #176
drmike
Default RE: CA Model XURAMA BIPLANE Build Glow Powered
tuny,
i have started on the bipe. doing the nose a little different. will let you know more later.
mike
Old 11-14-2011, 02:59 PM
  #177
mithrandir
mithrandir's Avatar
very big canalizer!
lol
Old 12-25-2011, 03:31 PM
  #178
Ricardo M.
How are the other buildings going, any electric power ?
Thank you.
Old 12-26-2011, 06:00 AM
  #179
tuny
Hello Ricardo, The new Xurama is on its way, with some small changes from this one. I will post pictures when I start, but still YS Power. I tried electrics and it doesn´t work for me. I find there is plenty of more power and much much much much more torque with a YS 175 than with any electric set up I have tried.
also another reason: It should be punished by law to fly a biplane with anything else than a 4 cycle!
TUNY
Old 12-26-2011, 09:36 AM
  #180
flyncajun
+1
Bryan
Old 12-26-2011, 12:19 PM
  #181
Torben Parsberg
Yes! Bibe with YS is,top of pop!
Old 12-26-2011, 02:42 PM
  #182
apereira
apereira's Avatar
+175!!!
Alejandro
Old 12-26-2011, 02:46 PM
  #183
alejo2012
Hi Tuny , I'm just starting with my xurama armed, because I was short of time and when I see the wings these are all along a depth of 5mm as if to pass the servo cable but in the whole scale of wing tip to tip and then the core of polystyrene is very fragile. The model was your way? it strikes me that the only thing you could do to fix it without adding much weight would be placed along the entire wing on the draft brings a 5mm carbon tube. do you think? if not understood you upload a picture to see.
thanks for all
Alejandro.
En español : Hola tuny , estoy recien comenzando con el armado de mi xurama , por que estuve falto de tiempo y cuando veo las alas estas tienen todo a lo largo un calado de 5mm como si fuese para pasar el cable del servo pero en toda la envergadura de las semialas de punta a punta y entonces el nucleo de telgopor es muy fragil . Las de tu modelo eran asi ? se me ocurre que lo unico que podria hacer para solucionarlo sin aumentar mucho el peso seria colocarle a lo largo de toda el alaen el calado que trae un tubo de carbono de 5mm . que te parece ?si no se entiende te subo una foto para que veas.
gracias por todo
Old 12-26-2011, 03:16 PM
  #184
Tim Redelman
My Feedback: (36)
Tim Redelman's Avatar
Tuni, AWESOME work !!!!
Congratulations and thanks for inspiring all of us.
I couldn't resist posting these couple of pictures of your dad, my son, you (Batman), myself, and my Byron A-4. !!!!!!! (and my cuban cigar) LOL.
Jack.
And look at all that black hair too!!!!
Old 12-27-2011, 05:14 AM
  #185
tuny
Alejandro, thatis the cavity for the servo wires, yes, it goes all the way to the wing tip, you can leave it like that, there is no structural damage whatsoever.
Ese es el calado para pasar los cables de los servos, dejalos tal cual estan, ya que no representan ningun riesgo estructural.
Saludos!
TUNY
Old 07-30-2012, 07:05 AM
  #186
tuny
Hello All!
After hundreds of flights on this biplane which is the best I have flown I decided to try to make some modifications of my own to create my own version and change a few things.
First also YS power, in my opinion is the only way to power a bipe, the power its incredible, the sound, smoke etc, all help to create a beautiful flight presentation, but this time no top hatch on the fuselage (i just glued permanently the supplied hatch and made a new one on the bottom)
then completely redesigned wings and stabs, this to get rid of the mixing and to enhance the awesome qualities of this bipe even more.
- more wing area
- new wing shape
- increased wingspan
- different airfoil
- smaller stabs
my goal was, better snaps (more crisp) better spins, both are incredible easy to stop
reduce coupling on rud-ail and rud-elev they are both almost gone, some fine tuning and rud-elev should be gone, rud ail will be gone on a future version.
I have to thank Bryan Hebert for all his help in this project! THANKS BRYAN!!!
some pics.
ID:	1787595   Click image for larger version
Old 07-30-2012, 10:08 AM
  #187
cdodom
cdodom's Avatar
That looks incredible Tuny!!! Can you post some pictures of the construction on the inside of the FUSE.
Chris Odom
Old 07-30-2012, 03:00 PM
  #188
flyncajun
Hi Yuny,
That looks Great!
I`m glad your done, Now you can work on building a Alferma
ALejandro says your going to built Two, one for you, and One for Him. LOL Just Kidding!
Great work as Always
Bryan
