E-Motion center of gravity
My Feedback: (85)
Getting close on getting the E-Motion going, checking the CG.
The instructions say: Schwerpunkt=195 von der Nasenleite gemessen.
Which i take is the center of gravity, But not being fluent in english and not being fluent in whatever language that was, German maybe.
Does anyone that has flown one of these have a preferred center of gravity?
195mm is behind the wing tube. it might be correct, then again maybe not.
Any help
Any help
VA
RE: E-Motion center of gravity
I don't have the mesrurement but I'm flying with the Himax motor and castle useing Power Unlimited batteries. I put the battery back over hanging about 3/4 of inch behind the landing pad,and it fly fine. The same has been for if you use a Petty we have try it and it made no differnce. If I get a chance I'll take a picture and put wing on and get some number for you. What are you useing for power? we have flown four of them and all same place.
Jr
Jr
I looked at my notes and I had settled on 195mm back from the LE at the root. I think this is 29%MAC if memory serves.
Your batteries will hang off the back of the stock tray.
I think I started at 185mm and found the plane flew (especially rolls) better and better as I moved the CG back to 195.
Dan
Dan
