Servo play
My Feedback: (50)
Servo play
I have two Hitec 5645s that im getting 1/8in of play in them Im using a SWB 1-3/4 is this normal theres not as much play with the smaller arms as there is with the bigger arms the arms are new and fit tight The servos are new first time I used them
Thanks Tim
Thanks Tim
RE: Servo play
ORIGINAL: rcpilot_971 I have two Hitec 5645s that im getting 1/8in of play in them Im using a SWB 1-3/4 is this normal theres not as much play with the smaller arms as there is with the bigger arms the arms are new and fit tight The servos are new first time I used them Thanks Tim
A very long single arm, the longer the servo arm, the more the natural play in a gear train is accentuated and the torque is reduced accordingly. Servo torque (How is it measured)
Always use the shortest horn and use the closest hole to the output shaft as possible.
Whilst appearing "tight" is the spline count correct? This as Futaba horns may appear to fit but do slip under load. Servo - Horn arm Spline Count and Inter Brand Compatibility
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
RE: Servo play
Hi!
Metal geared servos have always more play compared to nylon gear servos.
But as long as you follow the simple rule that says: Always use the shortest possible servo arm as possible and the longest rudder/aileron/elevator arm as possible...everything will be fine.
Beware that Hitec, Futaba and JR have different numbers of splines in the servo arms.JR has 23, Futaba 25 and Hitec 24.
