PROGRAMING THE FUTABA FG8
CA
Just replaced a Futaba 9C with a Futaba FG8. Manual that comes with the system leaves a lot to be desired when it come to programing. I've managed to do O.K. despite the manual, however I'm down to one last problem (that I know of): how to program the dual rate 'toggle' switchs for aileron, elevator, rudder. My research says LNK menu, then Function menu but for me I run into a dead end.
Suggestions??????
Suggestions??????
1 Post
RE: PROGRAMING THE FUTABA FG8
model menu / dual rates / switch.You can set 5 rates. The first rate does not have a switch. Simply set the DR and exp. Then for your next DR set the switch to which ever you desire.
