Need help with my first build
Hey All,
I've starting building an airboat and now its time to get the mechanical/electrical components together. I'm new to the RC world and Ive read up on the various parts needed but I figured I should ask some experts for some help.
A friend gave me a box of rc scrap parts, mostly from a Hobbico Skyfly and a cheap rc truck. From the Skyfly I have the transmitter(3-channel FM) and a brushed 380 motor. From the cheap rc truck all Ican reasonable salvage is ESC circuit board and a servo(it has no name or markings on it). I also have a NiCd 9.6V 700mAh battery that ive been using to test stuff and seems to hold a charge. I figured I would start working around the parts I have and if i need to replace them I will. I'm also looking to keep my costs down since its my first build.
I figure I need a reciever first but I'm not sure how to figure out which would be compatible with the transmitter. Can anyone lend some advice?
RE: Need help with my first build
Well you really shouldn't use a 72 mhz radio on a boat or car. That frequency is reserved for airplanes. How about a simple entry level 2.4 system like this?
http://www.hobbyking.com/hobbyking/s...dProduct=15141
ORIGINAL: JoeBoater
Hey All,
A friend gave me a box of rc scrap parts, mostly from a Hobbico Skyfly and a cheap rc truck. From the Skyfly I have the transmitter(3-channel FM) and a brushed 380 motor. From the cheap rc truck all I can reasonable salvage is ESC circuit board and a servo(it has no name or markings on it). I also have a NiCd 9.6V 700mAh battery that ive been using to test stuff and seems to hold a charge. I figured I would start working around the parts I have and if i need to replace them I will. I'm also looking to keep my costs down since its my first build.
Hey All,
Good luck with the boat. I always had fun fooling around with cast offs from other people to see if I could get something going out of it. But a decent radio will save you a lot of grief in the long run.
Well after evaluating all the components I have trying to figure this out I realized I actually have no idea what I'm doing. Im not sure if I should continue to try to use the components I have now and continue working around them or just buy all new ones that Iknow will work together. I'm hoping someone can help me with this. I took a picture of the parts that I have and a rundown of what i personally think.
Brushed 380 motor- It works and the prop I have made the boat glide across my kitchen floor @ 50% throttle. I'd like to use this just to not have to purchase a new brushless and then a expensive ESC for it.
ESC- this is a cheap unit that Ipulled out of an RC truck(same size motor), I assumed I could throw some connectors on it but now i'm not sure. used with the 9.6V batt
Servo(no name)- it turn boths directions fine but doesnt appear to have any limits as i can have it spin in either direction for several rotations. Also needs connectors, also used a 9.6V batt
Batter- This is the 9.6V, 700mAh. holds a charge for a decent lenght of time, but i was thinking of getting a larger backup as I dont see this lasting very long
So thats what I have. Im definitely going to go with the Tx/Rx system that Texastbird recommended, but after that Im at a loss. Anyone want to help a newb deisgn his first build? I'd greatly appreciate any help.
