Should Hitec replace planes from lock outs
#126
RE: Should Hitec replace planes from lock outs
ORIGINAL: K-Bob
Now that's a strange feature indeed. Whenever I turn my transmitter on I always want to transmit. Using all 80 channels and hopping a few hundred times a second, my Futaba surely isn't tying up any frequencies.
ORIGINAL: JIMF14D
It is not a question of being a cheap radio. It is a saftey feature since the A9 can be configured to operate on either 2.4 and 72. It reminds you to check your channel/pin if you are on 72. It also allows you to do set up on your radio without radiating or tying up a channel at the field.
You should try one, you may actually learn that there is a whole new world out there.
Jim D
Jim D
#127
MD
It's what I would do with a radio that doesn't do the job:
http://www.flickr.com/photos/shirley...rs/2141584770/
#128
ORIGINAL: K-Bob
Wow that's a strange feature indeed. Whenever I turn my transmitter on I always want to transmit. Using all 80 channels and hopping a few hundred times a second, my Futaba surely isn't tying up any frequencies.
Mike.
#130
The end user (meaning You) accepts total responsibilty for what you fly. Planes crash, thats part of the hobby. All model airplanes are disposable items including the expensive ones. Don't fly anything you can't watch go into the ground. enough said.
#131
NY
Mike, do you think the new 3.oxxxx software should be installed if we are not flying any ignition engines. Will the new module software work with Rxs that are not updated?
Not all my Rx are easy to access as Ihave some bipes that require taking the wings off...
In 18 months I have no link hicups with glow and EP power...knock on wood!
Jim D.
Jim D.
#132
MI
So very sorry for your loss, I never care to see a crash, for any reason. I will say I am a newbie to the RCportion of the air modelling hobby. I will also say that I have been an electronics technician/repairman for the last 35 years. I have seen a lot of failures in a lot of equipment. cold solder joints on pc boards can give the impression that all is ok, yet breakdown in a short, or, sometimes long period of time. EMP interference is always going to be a problem. The "High dollar radio setups" kept me out of the RC aspect of building and flying aircraft for a long time. Nowadays, with the Hobbyking, Turnigy, Orange type of pricing I can enjoy this part of the hobby as well. I own a well used Futatba FM tx, but I use Corona rx's with it. I WON"T pay the price for futaba rx's. I also own a new Turnigy 9x radio, and am pleased as punch with it. I have had no crashes due to radio failures, only my own. I think with the money made from the Hitec, Futaba,etc names, they should not only be able to pay for your plane, they should do so in the intrest of good customer service, which may be to their best intrest. "Just because it costs more, doesn't make it better". Better customer service makes it better!!
I was told by an Old-timer, "If you ain't ready to crash, You ain't ready to fly" as he walked back to his truck with a monokote bag full of busted balsa...[8D]
