Futaba T7C neck strap balance
I have a T7C, and am currently using a neck strap attached to the middle. Is there some other strap or accessory to keep it in balance? Because now the side of my body goes down, so when I'm flying I constantly have to make an effort to keep it level.
RE: Futaba T7C neck strap balance
Yes it is called Neck Strap Balancer that attaches to the stock strap mounting on your Tx and is available from Tower Hobbies, HK and other accessory outlets.
Karol
Karol
ORIGINAL: theodm
Thanks, found it. Will need to open the controller it seems to rotate the hook 90 degrees...
