HELP! No throttle on redcat rc
I have a redcat rampage mt with a hexfly servo hx-15s which when purchased worked fine i bought this truck second hand ran it bout 30 minutes just around the yard no jumps or humps just trying to get the feel for truck the battery pack dies for the recieve charge battery as directed throttle servo wotks bout 5 minutes and completely quit the fail safe is working and the throttle is transmitting to receiver but no throttle at servo removed the bottom from servo wiring is still connected but it smells as if its been very hot a few times any help would be greatly appreciated
Does the throttle servo move at all, or make any noise when using the transmitter trigger/stick? If not, then make sure you have a fully charged receiver pack; plug the steering servo into channel 2 (throttle) on the receiver. Take your transmitter trigger and move it. If your steering servo is moving while you are using the trigger/stick, your first (bad smelling) servo is more than likely shot. Plug your steering servo back into channel 1 and order a new servo for your throttle.
Sorry, that's the best I can do to understand your situation.
