RC Loses Signal
RC Loses Signal
I am new to the RC game. I bought an RC Buggy and it runs great. Problem I have is that it goes for about 50 or so feet and then loses its signal and doesn't run. When I walk up to it, I have to get to within about 10 feet before it gains the signal back and runs again as before. Being new to this, not sure what I can do to fix the issue of signal loss. Does anyone have any suggestions on what might be the problem?
Without knowing what radio and what frequency you are using it is hard to even suggest a reason. Have you checked to make sure that the antenna an both the transmitter and receiver are properly attached and deployed? Are your batteries fully charged?
The frequency is 2.4 ghz. Have replaced with new fully charged battery and new batteries in the remote, with same results. Sorry, new to this - where would I find what radio it is?
Sending it back will likely cost more than a new RX/TX combo. You can get a 2 ch flysky for $20, or 3 channel for $30. Try swapping the TX, to see if the car with short range works good with the different transmitter. If not, then it's the receiver.
Hubert
Hubert
