changing frequency ?
Unless you have the proper license you cannot change the frequency of a transmitter. I do believe Pete Waters at Kraft Midwest in Northville Michigan is a good source. The transmitter will need retuning since this is a major excursion in frequency. Futaba factory service may also accomodate,but Pete is probably the most experienced person in tne Biz. I hope he NEVER retires
My Feedback: (16)
GA
Changing the frequency from 72Mhz to 75Mhz will greatly decrease the range unless the receiver is re-tuned. I guess to really do it depends on the on the reduced range. I would recommend that you send the receiver to a service center and have the receiver re-tuned.
