Royal evo flap programming!!!!! help :(
MB, CANADA
I have a re 12 and I need to program the flaps..I cant figure this out..I need each flap to have its own servo on individual channels, I need to be able to slow down the servo for realistic behavior. I will eventually be mixing flap to aileron and others, but for now what should I do? I can get the flaps to work on a 3 position toggle, but I cant get the servo speed adjustment option to slow them down.
Any takers...thanks guys
RE: Royal evo flap programming!!!!! help :(
Presumably you have:
assigned the flap function to that switch;
assigned those servos to flap and not to a mixer at the moment;
adjusted the speed in the flap control menu for that flight phase.
If you have done that, it must work.
If you are using that switch to also change flight phase at the same time it can cause some odd events as the slow phase change interacts with the slow flap.
H.
H.
