damp receiver junk or not ?
I have a receiver that spent some time in the rain ( it was stuck
in the top of a tree OK ) The receiver was wraped in foam and
spent the majority of the summer in the elements. I opened
it up and there was moisture inside the case. Is this worth
sending in to Futaba or is it a lost cause, if so what are the
rates do they charge to check them out ???
My Feedback: (20)
Open the case and let it air dry. Don't use a heat gun or hairdryer, just let it air dry for a few days.
Then plug up everything and do a range check. If it is range checking as far as it did before, go fly. If it doesn't, send it in.
I used to do a lot of airboat racing in the 80's and my receivers invariably got wet when the boat flipped. Maintenance was as above and it always worked as advertised.
YMMV
Don
YMMV
Don
