Hitec hs 225 mg refund
I recently had lost a plane due to Hitec hs 225 mg having a mind of their own. This was the second set of 225s that I had problems with. The first set I sent to Hitec and they sent me new ones. Well the new ones took a plane down. So I sent Hitec the servos for the second time along with pictures of the pieces and explained to them I did not have any need for another set of 225s because of plane being gone. I also explained the need for some digital servos in my 27% bipe. So after about 3 weeks and 5 emails 4 HS5645 DIGITAL HI-TORQUE servos and a extra hs 635 showed up at my door. (SWWEEEETTT) I will definately keep buying Hitec after they replaced 90% of my lost plane with digitals for my current money pit..
Thanks for the great service Hitec
AP
AP
RE: Hitec hs 225 mg refund
Service is great, no doubt.
Though i will not buy any of their stuff in this lifetime.
I had about 6 Hitec servos (out of 10) that have failed. Two of them 225MG-s.
Burnt out electrics, pots acting up, motors failing and stripped gears without apparent reason (throttle).
Nothing will overweight that failure rate, not even great service.
regards,
Zaquron
ps: please ignore this if you're still a Hitec fan, but i prefer QUALITY (and safety) over service...
regards,
Zaquron
