Li-Ion versus Li-Po on receviers and ignitions
Old 08-09-2006, 04:17 PM
Rush7
My Feedback: (74)
Rush7's Avatar
Default Li-Ion versus Li-Po on receviers and ignitions
Why is it that most big planes that I have saw lately are flying with Li-Ion batteries on the receiver and ignition. i thought that Li-Po's were the latest and greatest technology.
I guess the point that I am trying to get to here is why would you not just run Li-po's instead.
What are the advantages and disadvantages of Li-Po's and Li-Ions on your recevier and ignition systems?
Thanks for any advice....
Old 08-09-2006, 08:23 PM
Panzlflyer
My Feedback: (15)
Panzlflyer's Avatar
Default RE: Li-Ion versus Li-Po on receviers and ignitions
Vibration and the fragile nature of the package in a high vibration enviroment Vs cylyndrical casing that is a bit more robust, but sacrificing higher current ratings.
Old 08-10-2006, 08:02 AM
Zeeb
My Feedback: (41)
Zeeb's Avatar
I don't pretend to be a battery expert, but from the research I've done the Li-Ion is more stable and less likely to cause fires if slightly mis-handled or damaged than the Li-Poly. However the Li-Ion does not have the discharge rate capability of the Li-Poly which is why you find them in electric powered applications.
So I use Li-Ion for rx/ignition on my latest model and Li-Poly on my foamies which are the only electric powered stuff I have.
There is a new chemistry of Lithium/Manganese coming out, although they are somewhat limited in sizes and availability right now, which has the promise of the discharge rates of Li-Poly without the hazards as it's not the volatile chemical combination of the Li-Poly's.
Duralite has the new stuff, but not much information about them is posted;
http://www.duralitebatteries.com/batteries-mg.html
