paper tubes
Old 01-21-2003, 04:18 PM
halflight
Default paper tubes
Do you know of a simple way to make paper tubes so I can run the servo wire through the wing?
Thanks.
Old 01-21-2003, 04:49 PM
JWN
Community Moderators
My Feedback: (42)
JWN's Avatar
Default paper tubes
Estes model rocket tubes work great and are pretty light. Or, you can just roll up a piece of paper around a piece of dowel, slide the rolled up paper into the holes in the ribs and let it go. It will then unroll to the size of the holes.
John
Old 01-21-2003, 04:51 PM
Mettler1
Default real simple!
When I built my Sig Something Extra the kit came with a couple of sheets of paper. You rolled them up and stuck them in the wing rib holes. Then you glued them to the wing ribs. Seemed to easy to me but it works!
Old 01-22-2003, 02:49 AM
Vince
Default paper tubes
Cactus has a package of 8 1/2" I.D. paper tubes 36" long for $9.95.
Vince
Old 01-22-2003, 06:57 AM
AndySteere
AndySteere's Avatar
Default paper tubes
Don's Hobby is selling what I think is the same thing as Cactus. Thin paper that doesn't weigh hardly anything, but strong enough to keep servo wires in check.
Here's a pic (its the black thing on the left):
(Click for larger version)
Kept the three servo wires held firmly to the top of the fuse (on the left in this pic), so that the antenna wire (in a pushrod tube on the right) would never come close. The tube is held in place with a little CA on each end. Sure makes for a cleaner install.
Old 01-22-2003, 01:23 PM
zippo
Default paper tubes
Great photograph! How did you manage to take it?
Old 01-22-2003, 03:52 PM
AndySteere
AndySteere's Avatar
Default paper tubes
Zippo,
Thanks for the comment! The picture was taken by sticking the camera down into the fuse and snapping away. About the only time I've found the little LCD screen on the back of the digital camera to be useful... is when you can't get your head in there to look through the viewfinder.
Old 01-22-2003, 04:12 PM
zippo
Default paper tubes
Begs another question ...
(1) Either this is a huge aircraft; or
(2) Its a very small camera!
Did you use a flash while in there?
Old 01-22-2003, 04:17 PM
xp8103
My Feedback: (16)
xp8103's Avatar
Default paper tubes
I used brown paper bag wrapped around a cardboard tube and taped. Tube can be from anything the proper diameter for your application. Slide the tube out, instant free lightweight wire tube.
Old 01-22-2003, 04:38 PM
AndySteere
AndySteere's Avatar
Default paper tubes
It's large but not a huge plane (82" wingspan Gee Bee Y), and the camera is a standard sized digital camera (Olympus C700UZ). Yes, a flash was used. There are many other pics, including a zoomed-in shot of the tail's servos, at the website below.
On the tubes, I've done the make-it-yourself thing. Works fine and is very cheap, especially for short runs (like a foot). I didn't have as much luck with longer lengths though... kept unraveling. For the terminally lazy like me... the Cactus/Don's tubes are extremely light weight (6.2 grams for 36") and work very well. Of course, if you need bigger than 1/2" diameter or 36" long...
Old 01-22-2003, 07:10 PM
SitNFly
My Feedback: (54)
Default paper tubes
Go look at www.gatorrc.com for smaller diameter wing servo tubes.
Rein
Old 01-23-2003, 04:08 AM
Ed
Default Wing Tubes
The very best and easiest way, is to use aquarium tubes. These are the plastic tubes used in tropical fish tanks, and can be purchased any place that tank supplies are sold. The inside diameter should be at least 1/2", but bring your connector anyway. They have many different sizes.
[email protected]
Old 01-26-2003, 04:02 AM
RCRC
My Feedback: (56)
Default paper tubes
Buy a roll of heavy brown Kraft paper. You can roll it on a dowel & scotch tape it. Enough for a lifetime for a couple of bucks! Handy to wrap packages in too.
Old 02-01-2003, 12:37 AM
klbass
My Feedback: (7)
Default paper tubes
I buy shower rod covers. These are available at Lowes in the shower curtain/rod section. They are the plastic covers used to make your old rusty shower curtain rod look new again. They are light plastic and come in two or three colors, usually tan, black, or some other color. They are six feet in length and the diameter can be asjusted to whatever you like by twisting it, then CA in place. Cost 2.00.
Old 02-01-2003, 03:34 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Default paper tubes
I use a 3m transparency cover sheet rolled and ca'ed into place. It's lighter than the paper supplied in my kit, tougher, and is transparent.
