Futaba 2.4Ghz RX installation
Hi.
I want to install the two antennas from the reciever into two small plastic tubings. That seems like a very good solution that I've seen others use.
But I wonder if it hurts if the uncovered parts of the antennas are inside the tubings? Will that affect range?
RE: Futaba 2.4Ghz RX installation
Check out my setup. I was a bit nervous because of the carbon parts which in my mind might cause some shielding problems. Yesterday I maidened my 2.6 CARF Yak absolutely flawlessly. During the low power range check I had a max range of some 80 meters which is considerably more than the recommended 50 meters by futaba.
Joe
Joe
