X9303 setup for multiple servos
Would appreciate any tip or link on how to setup JR X9303 for multiple servos.
I have 2 servos on each aileron of my my SD-Model EXTRA-260 85cc but I don't have any match-box so I will be using primary and secondary channels and mixers.
Thanks in advance,
Yoav
Thanks in advance,
Yoav
RE: X9303 setup for multiple servos
Hold the ENT button down and turn on the radio to acccess the system menu.
Go into the WING TYPE menu
Highlight WING
Press the wheel and select FLAPERON
Now when you go into your menus you will have a LAIL and RAIL to set end points, subtrim etc on.
Highlight WING
Setting up Flaperons is a start, but Yoav said he had TWO aileron servos per Aileron half. That means he would either need Y harness or Matchbox between servos on each Aileron half or he would have to use up two more channels ( two channels per Aileron half) and mix all that together.
My Feedback: (41)
ORIGINAL: ytell
Thanks in advance,
Yoav
Thanks in advance,
Yoav
Some have done this and put the two servos with trim on one aileron and do trim flights, then re-set the mechanical linkages and/or subtrims for the other wing.
Personally, I would not suggest this solution but if you want to do a search or two on the forums you should be able to find it.
The new 12X has a specific mix to accomplish the four aileron servo mix with trim following, but I'd suggest a Matchbox or PE for your consideration when using the X9303...
