ORIGINAL: ytell
Would appreciate any tip or link on how to setup JR X9303 for multiple servos.
I have 2 servos on each aileron of my my SD-Model EXTRA-260 85cc but I don't have any match-box so I will be using primary and secondary channels and mixers.
Thanks in advance,
Yoav
There is a way to do this with the X9303 but you will not have trim following on two of the channels.
Some have done this and put the two servos with trim on one aileron and do trim flights, then re-set the mechanical linkages and/or subtrims for the other wing.
Personally, I would not suggest this solution but if you want to do a search or two on the forums you should be able to find it.
The new 12X has a specific mix to accomplish the four aileron servo mix with trim following, but I'd suggest a Matchbox or PE for your consideration when using the X9303...
