New Hitec Aurora 9-Channel 2.4Ghz Radio System
#3626
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
Hi,
I have just built a programming chart for the Aurora 9. Basically it a graphic representation linking the different screen menus of the Aurora 9.
This, together with the index I posted earlier, will give a printed visual representation that will allow you to navigate through the Aurora 9 menus and programming functions on paper before you actually turn on the transmitter.
Here is the link to the printable programming chart:
http://www.rcuniverse.com/forum/m_10...m.htm#10481073
As always, any suggestions for improvement are welcome. Hopefully you will find it useful.
Fly4Fun,
Wayne
Fly4Fun,
Wayne
#3629
MS
Just started with the A9 and was working thru the dual rates on plane. In my old forgetful ways i assigned the elev and aileron to the same switch. i didn't realize you could do that but it worked ok. also i have a TME tricke carger that i use so i plugged the hitec charger to it and then plugged in the tx. The TME pulses every second on my other futaba oem chargers(lights blink) but not on the hitec. Just curious about why.
Any thoughts or opinions welcome.
#3630
ORIGINAL: Lynn1953
#3632
ORIGINAL: Lynn1953 Just started with the A9 and was working thru the dual rates on plane. In my old forgetful ways i assigned the elev and aileron to the same switch. i didn't realize you could do that but it worked ok. also i have a TME tricke carger that i use so i plugged the hitec charger to it and then plugged in the tx. The TME pulses every second on my other futaba oem chargers(lights blink) but not on the hitec. Just curious about why. Any thoughts or opinions welcome.
Aurora 9 - Diode in TX Charge Circuit Never Jump TX Charge Circuit Diode - Hitec FAQ.
Aurora 9 - Lipo & Field Charging. includes Fast Charge Aurora, Eclipse 7, Flash 4&5, Laser, Optic 6, Prism 7 etc.
Aurora 9 - 110/230 Vac charger Charge Plug/adaptor sizes. [Red LED does not change to Green simply dims out but charge continues same rate].
"Chargers are designated as either CG-S42 / CG-S42k / CG-S45
- depends upon type of spades (prongs?) to fit area power supply as requested by distributor for each area.
Input 100-240 VAC 50/60Hz 0.1A
Output: TX 7.2VDC / 80 mA
RX 4.8VDc / 80 mA"
more under Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers - FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
#3633
MS
The TME is a power switch basically not a charger. it switches power on and off every second. I have used it for years with my other oem chargers to keep my tx and 4.8 rx batteries ready. i just don't understand why when the power is off for that 1 second the light on the hitec doesn't blink - it stays on.
it's not a trickle charger or a peak charger just a momentary power switch.
#3635
ORIGINAL: Lynn1953 The TME is a power switch basically not a charger. it switches power on and off every second. I have used it for years with my other oem chargers to keep my tx and 4.8 rx batteries ready. i just don't understand why when the power is off for that 1 second the light on the hitec doesn't blink - it stays on. it's not a trickle charger or a peak charger just a momentary power switch.
Unlike NiCD, NiMHbatteries should notbe trickle charged:
Aurora 9 - Battery is not charged. Charge before first use so as not to damage battery. Battery is 1300 mAh_charge rate is 80 mAh (to minimise damage if left on to long at any time) = 19-20 hours for first full charge - please read the further details.
Unfortunately, as we age and get superseded by a younger generation, so does our equipment...
Alan T.
#3637
OH
I have my A9 charger hooked up to my TME and it works as advertised, just have to look at it harder cause it's not as bright as my JR & Futaba wall warts, but it is blinking.
#3638
First off - I did not read this entire thread. Today is the first day that I have begun to seriously consider a Hitec 2.4 system. Before I spend 2hrs reading this entire thread, I kindly request your patience with a very simple question.
I don't want to start a poop storm, but.........
Does the darn thing WORK?
Futaba had problems with some of their FASST radios doing something weird if you turned them on and off again rapidly. I don't know the specifics, but it did something like "zero" all base parameters and if used after that, it would wreck any other FASST system in use at that field. This was a few years ago and I'm sure it's been fixed by now.
Spektrum comes un-bound all the time. I've personally seen people at our field standing in a pilot box, ready to taxi out and take off - and the plane will simply FREAK OUT and go full throttle into a fence or one of the storage buildings....... or simply stop responding all together.
DOES THE HITEC WORK? DOES IT WORK WELL?
(I'm not trying to stir the pot or start a brand war. I'm simply stating a couple reasons why I'm afraid of Spectrum and FASST. I'm in desperate need of a RELIABLE 2.4 system and the Hitec looks pretty good on paper.)
Thank you
Thank you
#3639
ORIGINAL: Rcpilot
Futaba had problems with some of their FASST radios doing something weird if you turned them on and off again rapidly. I don't know the specifics, but it did something like ''zero'' all base parameters and if used after that, it would wreck any other FASST system in use at that field. This was a few years ago and I'm sure it's been fixed by now.
Thank you
Thank you
I would not be afraid to use any product from Hitec, Futaba, JR, Spektrum, or Airtronics. I have two JR XP9303 radios with the Spektrum 2.4 RF Module and JR Synthesized 72Mhz RF Module. I plan to upgrade to a new 2.4 radio and JR or Spektrum would be my first choice since I have already invested in a number of JR/Spektrum receivers.
At present, the Spektrum DX8, JR 11X, Futaba 8FG, and Hitec A9 would be high on my list. The Hitec A9 is modular and could take a Spektrum RF Module. The 8FG's S-Bus technology is intriguing.
#3640
BuschBarber you got a private message.
Don't want to hijack this thread and turn it into brand bashing. It does nothing constructive. I've seen multiple issues with other offerings with my own 2 eyeballs, so I'm looking pretty seriously at the Hitec. I just want to know if it REALLY works the way it was intended.
#3641
CO
Hello fellow Arvadan,
I started my RC journey with a new Spektrum DX-7 in mid 2008. Being new to everything, I figured I must be doing something wrong when planes would mysteriously fly into the ground, or buildings, etc. I finally got enough confidence in my setup & abilities to start questioning the radio. Followed all Spektrum recommendations for install & usage, still had the occasional loss of contact or input different than I had requested. I was ready to give it all up, and read about the A9 in late 2009. Put in my request for one with Brad at Action RC in Feb 10, got mine about this time last year, and haven't had anything resembling a radio problem since. I've actually been able to start to learn how to fly better and set up planes now. Beyond the basics of "IT WORKS", it is a joy to program, will adjust about any way you can imagine, and is ultra-reliable.
Good luck in your quest, the A9 system is an amazing piece of work which a growing number of pilots are devoted to.
#3642
ORIGINAL: 20/20 Hindsight
I started my RC journey with a new Spektrum DX-7 in mid 2008. Being new to everything, I figured I must be doing something wrong when planes would mysteriously fly into the ground, or buildings, etc. I finally got enough confidence in my setup & abilities to start questioning the radio. Followed all Spektrum recommendations for install & usage, still had the occasional loss of contact or input different than I had requested. I was ready to give it all up, and read about the A9 in late 2009. Put in my request for one with Brad at Action RC in Feb 10, got mine about this time last year, and haven't had anything resembling a radio problem since. I've actually been able to start to learn how to fly better and set up planes now. Beyond the basics of ''IT WORKS'', it is a joy to program, will adjust about any way you can imagine, and is ultra-reliable.
I fly at the Arvada field. My name is Chris and I've been a volunteer instructor for about 10yrs on Thursday nights..... if that helps ya put a face to me. [:-]
#3643
Chris, I fly with it and I have not had any problems. I have read the entire thread and other threads, I have read about 1 or 2 cases of radio problems, but I think that was a quality control problem (I am sure that a small precent of every brand has a quality control problem, meaning if a company sells 10000 units there will always be 1 or 2 that has a bad wiring connection) but I don't think there is any major problem with the system. I personally like the afforability of the system and the telemetery.
Just my 2 cents worth.
Jon
Jon
#3645
TX
ORIGINAL: Rcpilot
First, let me say that in that time I have never had an incident of losing control of an airplane. That's a big improvement over 72mhz where I had the occasional "hit" and had two planes shot down by careless people turning on on my frequency.
I didn't like the Spektrum/JR radios. I don't like their style of programming and I don't think satellite receivers should be necessary. I too occasionally experienced apparent "loss of bind" but never on an operating plane. Instead once in a while I'd turn everything on and they would not link up, going through the bind process would correct this. The 12X was over priced and under-powered IMHO.
Futaba was flawless except for 2 things. The 12FG was rather complex to program and the manual was vague, and at the time there was a big controversy about receivers failing from excessive heat. I never experienced this but always worried. And the cost of receivers was very high.
The Airtronics worked perfectly, receivers are reasonably priced and the transmitter's programming was very complete, however I didn't like all the button pushing and scrolling that was necessary.
The A9 also works perfectly, the receivers are priced aggressively and the touch screen programming is the best. I settled on the A9 and have not regretted my decision. To answer your question "Yes they work". The only thing I'd change is to add a few more channels and some mix options, which hopefully they will do before I die.
TF
#3646
ORIGINAL: rctom
I've used every 2.4 system on the market (with the exception of the cheap chinese systems). I started when the DX6 came out and have progressed through DX7, x9303, JR 12x, Futaba 12FG, Airtronics SD-10G and now the Hitec A9.
First, let me say that in that time I have never had an incident of losing control of an airplane. That's a big improvement over 72mhz where I had the occasional ''hit'' and had two planes shot down by careless people turning on on my frequency.
I didn't like the Spektrum/JR radios. I don't like their style of programming and I don't think satellite receivers should be necessary. I too occasionally experienced apparent ''loss of bind'' but never on an operating plane. Instead once in a while I'd turn everything on and they would not link up, going through the bind process would correct this. The 12X was over priced and under-powered IMHO.
The A9 also works perfectly, the receivers are priced aggressively and the touch screen programming is the best. I settled on the A9 and have not regretted my decision. To answer your question ''Yes they work''. The only thing I'd change is to add a few more channels and some mix options, which hopefully they will do before I die.
TF
ORIGINAL: Rcpilot
TF
I've seen a lot of Spektrum radios lose bind and .............. generally freak out at our field. Frankly, from what I've witnessed with my own eyes, I'd be an idiot to buy and use one of those systems. Maybe it's just our field? They don't seam to be very reliable and knowing that, how could I live with myself if I was using a Spektrum system and lost a plane. What if it flew into someones face? Don't laugh, anything is possible with an out of control airplane. Could that be considered willful negligence?
I use a Futaba 12z at work. I can't stand it. Every time I have to program something, I end up wanting to take a friggin' sledge hammer to it. I can't stand Futaba programming. Some guys like it or get used to it. I hate it.
I was looking at the Airtronics 8000 radio, but found out they are missing expo or dual rates on rudder.......... something like that. Can't remember exactly, but it was, in my mind, a basic programming option on any 8ch radio system and Airtronics decided to leave it out. I am flying larger planes now (30cc - 75cc) Having dual rates and expo on all flight control surfaces is mandatory for me.
I've taken the time to go back through this thread and read a lot of it. I think I last looked at page 51 or 52. [:-] So far everything about the Hitec looks really good. I'll have to re-train myself on programming. I'm used to programming JR radios. I've been flying JR for about 13yrs. I don't count the Futaba that I use at work because I still don't "get it" when it comes to their programming.
#3647
My Feedback: (55)
I have owned, most recently, Futaba 9C, 14MZ, 12Z, JR 9303, JR 12X, Airtronics SD-10G and the Aurora 9. Today I have only the A9 and the 12Z. The Airtronics SD-10G is a sleeping giant and the manual for it is far and away the best for any radio sold in the US. For those who have issues with programming the upper end Futaba I certainly empathize with you and blame it on their disgusting manual. It took me a year to get my arms around the 14MZ (same as the 12Z) but, once I did I realized how flexible and powerful it is. There is nothing sold in the US that can hold a candle to the Futaba programming at that level. Surprisingly the A9 and the Futaba have similar programming approaches and in many cases if you can do a function in one radio you darn near know how to do the same in the other. If you know either brand then the other should not be hard to learn. However, I don't want to leave the impression that the A9 is on the same level with the 12Z or 14MZ because it misses that mark by a very wide margin. You can make a case that a number of the features on the Futaba are rarely used and so they don't count and I would agree. The hysterysis setting for sliders and volumes is an example. The key to the Futaba programming is to know what takes place in the 'Linkage' menu and what takes place in the 'Model" menu and neither word, linkage or model have anything to do with what is different or what takes place. For example, both the A9 and the Futaba allows you to set a servo speed for a particular channel but, the Futaba will allow you to set the servo speed for "functions" and then link that speed to slave channels if you want to the A9 cannot do that. Is that important, well if you have a complicated scale plane or jet I can think of many ways it would be helpful.
My personal take is that I am lucky to be a participant at a time when so many fun and exceptional radios are available from an industry that has extraordinary customer service.
Howard
Howard
#3648
ORIGINAL: Howard
For example, both the A9 and the Futaba allows you to set a servo speed for a particular channel but, the Futaba will allow you to set the servo speed for ''functions'' and then link that speed to slave channels if you want to the A9 cannot do that. Is that important, well if you have a complicated scale plane or jet I can think of many ways it would be helpful.
Howard
Howard
Mike.
#3649
My Feedback: (55)
ORIGINAL: MikeMayberry
Howard- Thanks for your insight. FYI: The servo speeds are assignable per the flight conditions plus you have the ability to manipulate the speed of the slave with a p-mix with ''ACC'' so there may be a way to acheive what you are reffering to.
Mike.
ORIGINAL: Howard
Howard
Howard
Mike.
Yes, you can come close by using p-mix and acc and adding delays through the flight conditions and be very close to what you need. It would be much easier and quicker to be able to link functions and not just channel trims both of which can be done with the Futaba. I chose the A9 as the backup for my 12Z and I had my choice of any radio sold in the US. I also had an opportunity to use Hitec customer service and it was exceptional and immediate. Put my name on the list for the new A16 please.
Howard
#3650
IL
Spectra pro, where are you? Come out come out wherever you are! Anyone know the status of the module. Waiting sucks.
