New Hitec Aurora 9-Channel 2.4Ghz Radio System
#3601
My Feedback: (198)
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
ORIGINAL: A.T.
Hitec 2.4 GHz AFHSS Equipment Update Manual
'WARNING
After the firmware upgrade, you must perform a range check and full ground before the first flight. "
IDreset is not mentioned as being necessary.
However, with update toV3.01, given the changes, and as one of the older generation who has experiencedchanges to firmware in different equipment with interesting results over many years, decided it was prudent to rebind my Optima transceivers.
Thisso as to also familiarise myself with the new scan function procedure - whichthen requires all other Optima/Minima then be re-set (rebound) to the modules new ID code.
Alan T.
ORIGINAL: Bob Pastorello So, Alan, I think you told me from these links - NO - I don't *need* to upgrade, but YES - I will need to rebind every receiver as a precaution if I choose to update the module. Is that the bottom line?
'WARNING
Alan T.
Thanks, Alan.
#3603
Loved the ''older generation'' part.....''experienced changes''....I can definitely relate. Kinda like WAAAAAYYYY back when Windows said it could be installed on a DOS machine without saving everything.... (Now the whole RCU world knows how old I am)
Thanks, Alan.
ORIGINAL: A.T.
'WARNING
After the firmware upgrade, you must perform a range check and full ground before the first flight. ''
ID reset is not mentioned as being necessary.
However, with update to V3.01, given the changes, and as one of the older generation who has experienced changes to firmware in different equipment with interesting results over many years, decided it was prudent to rebind my Optima transceivers.
This so as to also familiarise myself with the new scan function procedure - which then requires all other Optima/Minima then be re-set (rebound) to the modules new ID code.
Alan T.
'WARNING
Alan T.
Thanks, Alan.
Remember GEM, a competitor to Windows 1?
#3606
OR
ORIGINAL: BuschBarber
CPM - I do not recognize that. Did you mean CBM?
ORIGINAL: bgw45
Remember CPM, Crushed by windows...
#3607
ORIGINAL: 42etus
Heck, I remember CPM and I'm not that old...................................at least I never used to be.[X(]
ORIGINAL: bgw45
#3608
OR
ORIGINAL: 42etus
ORIGINAL: bgw45
See this: http://en.wikipedia.org/wiki/CP/M
#3609
My Feedback: (198)
ORIGINAL: 42etus
CPM = Control Program for Microcomputers
ORIGINAL: 42etus
ORIGINAL: bgw45
Just think - it probably has more instruction code and built in processor power than Cape Canaveral did when Freedom 7 blasted off.
#3613
NC
Hello all. I bought an Aurora 9 in Nov. last year & it is just now that I'm playing with it. A couple surgery's & other things kept me from doing anything for a while. I have read the book & I even updated the transmitter, module, & all 4 receveirs that I have. Now, for what might seem like a stupid question, "How do I run the short (compaired to 72mhz receveirs) antena wire? & does it have to be outside the fuselage? or can it (should it) be inside the fuselage? Must the wire be straight? or can it be looped or curved from the rec. to the holder? I have the niffty little plasic holders that came with the radio & each receiver, but I found it a lot easier to drill a hole through a piece of balsa & fit the antena into that hole to hold it snug. Here are a few picture of how I did 2 of my planes, but if I did this wrong, then I do not want to continue till I find out which way is correct. Thanks for any help you might provide on this, Bill
#3614
I just received my new Hitec A-9. Very impressive and great looking radio. Now to figure it all out!
Only one complaint. I have this great new Hitec radio and I have to fly it with my old Futaba 1024 neck strap. I guess I'll order a Hitec neck strap.
The manual says on page 22, "It is strongly recommended to use Hitec "S" Heavy Duty High Channel Switch Harness with Receiver Charger Cord (Stock # 54407S) for Optima serivs Receivers". What does this mean? I fly larger planes and use the HD EMS switch.
#3615
Hi,
I have a hard time easily finding what I want in the Aurora 9 manual. All information is in the manual, it is just hard to find it. The manual has a good table of contents but no alphabetic index to make it easy to find things.
As a result I put to gether an index that can be printed, trimmed and put inside back cove of the manual for easy reference. Here is the link to download the PDF:
http://www.rcuniverse.com/forum/m_10...m.htm#10467839
Earlier in this thread there is also a link to a computer searchable A9 manual posted by A.T. If you would rather have a searchable manual on your PC, you may want to download it.
Hope you find this useful.
Fly4Fun,
Wayne
Fly4Fun,
Wayne
#3616
Thank you Wayne. It's downloaded, printed and in my manual. I'll look for A.T's manual also.
I remember when the toughest thing to figure out on a new TX was which way to flip the servo reverse switches!
#3617
OR
MILDBILL
I do exactly what you have done with no problems at all. I find it easier to make my own mount to suit each plane than to use the supplied Hitec mount.
42
42
#3618
Hi,
The searchable manual link is in A.T.'s post 3471 in this thread on page 139.
Hope this helps.
Fly4Fun,
Wayne
Hope this helps.
Fly4Fun,
Wayne
#3619
"The searchable manual link is in A.T.'s post 3471 in this thread on page 139."
Downloaded and searchable. Very cool.
Thanks for all the help Wayne.
#3621
ORIGINAL: MILDBILL-RCU Hello all. I bought an Aurora 9 in Nov. last year & it is just now that I'm playing with it. A couple surgery's & other things kept me from doing anything for a while. I have read the book & I even updated the transmitter, module, & all 4 receveirs that I have. Now, for what might seem like a stupid question, "How do I run the short (compaired to 72mhz receveirs) antena wire? & does it have to be outside the fuselage? or can it (should it) be inside the fuselage? Must the wire be straight? or can it be looped or curved from the rec. to the holder? I have the niffty little plasic holders that came with the radio & each receiver, but I found it a lot easier to drill a hole through a piece of balsa & fit the antena into that hole to hold it snug. Here are a few picture of how I did 2 of my planes, but if I did this wrong, then I do not want to continue till I find out which way is correct. Thanks for any help you might provide on this, Bill
The following may be of interest:
Optima Transceiver (RX) - Installation RX & BODA Antenna FAQ, Volts & Range Test Results. {Regularily Updated with Q&A}
Carbon Fiber Fuse... Report - from well known Glider Pilot and Fly RC author Mike Lee
Aurora 9 - Giant Scale set up Brandon Chitty's 42% Aeroworks Yak - Video presentation of set up.
Range Test Procedure (#5.)
Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers - FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
#3622
NC
Thank you A.T. that helps alot. I think I am ready to go maiden this radio tomorrow evening, Sat. evening for sure. 42 was also big help with a pm on the subject. I am finding that this is easy to understand as to setting up each model & its features. I have set the 4 receivers into some older planes & I really like it so far. Thanks again for the help, Bill
#3623
Hi,
I've just identified 2 problems that I can not solve. I'm hoping someone can help.
In order to do some testing, I set up a new model called "TEST", I went through the new model menus and set up model type, wing type, tail type, engine type etc.
1. I would now like to delete "TEST" from my model selection, but I can not seem to do it. I've tried resetting the model, renaming it to blanks. After renaming it to blanks it now shows on the model menu as "ACRO:NONAME-#". Does anyone know how to erase this model from the model selection menu?
2. Also, while doing my testing, I had set up an engine type, but later wanted to change it. Does anyone know how you can go back into a model and change the engine type after you have set up a model?
Thanks for your help.
Fly4Fun,
Wayne
Fly4Fun,
Wayne
#3624
Reset or Delete a Model
1. Turn on Aurora, select and open another model.
. Go back to model name index, highlight the one to be deleted.
. The option[Delete] willappear center right icon in lieu of [Reset]
2. Use [Reset] option to fully reset that model or if just the engine, select [System] >[Model Type] and then the Acro/Hel/Glid icon. - best to reset as Model typeis first in parameters line and will effect all other parameters.
Alan T.
ORIGINAL: Wayne Miller Hi, I've just identified 2 problems that I can not solve. I'm hoping someone can help.
In order to do some testing, I set up a new model called "TEST", I went through the new model menus and set up model type, wing type, tail type, engine type etc.1. I would now like to delete "TEST" from my model selection, but I can not seem to do it. I've tried resetting the model, renaming it to blanks. After renaming it to blanks it now shows on the model menu as "ACRO:NONAME-#". Does anyone know how to erase this model from the model selection menu?2. Also, while doing my testing, I had set up an engine type, but later wanted to change it. Does anyone know how you can go back into a model and change the engine type after you have set up a model? Thanks for your help. Fly4Fun,Wayne
Alan T.
