when my motor is off and i roll my car it makes a clicking noise in the front differential.
when my motor is off and i just push my car on the ground it clicks in the front differential....whats the problem
RE: when my motor is off and i roll my car it makes a clicking noise in the front differential.
ORIGINAL: nitroboy01
check diff light sould come on
ah - but the bulb might be out.... smart-arse....
Jeff S.
PA
lol nitroboy. anyway, what type of diff is it? one-way, or spool?
if it is a bevel diff take it out and take it apart and put it back together again. if it needs oil, top it off too. thats what i would do, but find out what other people think first.
i bet i know what it is...take look at your outdrive dogbones...when you go to push the car youll see your dogbones in the drive axels jumping around in your outdrives creating that clicking sound...i had the same problem and checked everything thing there was. then i just thought to look there and i seen that the dog bone will ride up then when the pin is completely vertical itll fall. if not this then maybe try the other post
