clutch adjustment?
KY
clutch adjustment?
Can you adjust the clutch on the tc3+ at all. Doesn't seem like its hooking up off the bottom as well as before. Could be I need to lean the lsn also, cause it blows alot of smoke from dead stop. Just curious about the clutch though.
RE: clutch adjustment?
If you have had it a bit - remove the clutch and sand the shoes till they are white again - when they get loaded with the grease and oil fromt he engine, they become slippery and the problem you stated happens.
