OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
#5576
RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Even with a 36mm flywheel on mine, and the engine as low as it can possibly go (i have just over 1/16 clearance between the chassis and case) i still have yet to find a starterbox that would hit the flywheel on mine.
If you find one that works good id like to know, as the handheld starter i use works, but id like to put it back to use for starting the engines in my boats so i can get rid of the pullstarts.
#5577
My Feedback: (27)
I use a starter box on mine. I have the stock T15 motor that has the mounts built into the crankcase along with the stock flywheel. The engine still has the rotostart attatched. The box I have is an Ofna True Start universal starter box. the car need to sit forward on the box a bit and then I push the tire of the car right up against the side of the box. this get the starting wheel and the fly wheel to line up perfectly. There is no moddification to the car, the engine or the flywheel needed. At least not for mine. there may be something different to do if your are running a different engine with seperate mounts though. Here is a video of starting the car on the box.
http://s129.photobucket.com/albums/p...t=M2U00452.mp4
http://s129.photobucket.com/albums/p...t=M2U00453.mp4
#5579
Was that a 132' drag track?
Sorry for the delay in pics....got a couple this evening.
It is missing the muffler,mirrors need installed,tint and cut the windows to look rolled down,and wire up the lights so it's not finished.I also have intercooler piping with couplers and hose clamps that need to go in.
The Terry's Automotive logo is a window cling and removable,just playin around.
#5580
Nice looking body Galaxy!
I added a few electric RS4's to my collection this week.
I will post pics of them along with some pics of my Kamikaze foams!
#5581
I think it was. But I will double check on that. I also found out my cars top speed and I didn't like it.... It was 55mph. Doesn't HPI claim it runs 50 out of the box? I had the 41/45 spur gears with the red and yellow pinion gears. Everything on my car has been changed, I have made it a lot lighter with carbon fiber parts and titanium screws and turnbuckles, even have the 18tz engine. I expected I would be running 65 with this gearing. But I have now installed 39/43 spur gears, but will have to wait a few weeks to get back on the track.
#5582
something is definetely wrong there... you should for sure be getting more then 55mph. I ran almost 57mph with my RS4 with modded T3.0 on 23/43 gearing.
#5583
I should if done some tunning. It was getting late too. But I will be working in that. Any tips? Thanx for your help in advance.
#5585
ORIGINAL: Car-Boy
#5586
So, i did alittle photoshoot after i winterized my rs4 3.3. i think it looks pretty good...take a look. I slammed it and now it sits on a shelf to be displayed.
#5588
It was on my tool box, and the poster is on the wall in back of it...but i know, i thought of, people are going to say, why is there a mustang in the background of a cuda....lol
#5590
VA
whats the biggest engine you can put in one of this car i have only had electric i want to try the nitro onroad i can handle speed i have a 50mph brushless slash but i want to try something new and go nitro
#5591
My Feedback: (27)
Most small block engines will fit with little or no modification, but if you really want to go nuts you can stuff a big block in there as well.
Check out this thread to see what i mean
http://www.rcuniverse.com/forum/m_8246301/tm.htm
#5592
Going nitro will cost more and more. You can stuff a big block in a rs4 with some new mounts and some mods. I stuffed in a traxxas 3.3 in mine, i was going to do a big block .21 but got a 3.3 for 25 bucks basicly brand new...so i had to use it. If you use anything bigger then a .21 your going to run into tracsion problems because of too much torque. If you want what everyone is using thats running some of the fastest on road touring cars, get the picco p3 evo. And have it modded. Everyone has seem to have very good luck withit.....only downside, is your goingt to pay for it..i beleieve its going for 300 new...then another 100 or so to mod it.
Good luck with the build..
Tom
Tom
#5594
VA
what motor mounts did you use to get it to fit and can you give a part number
ORIGINAL: Fuel Crazy
21 is actually pretty easy to swap in. You just gotta get a little creative with the pipe.
#5596
ORIGINAL: momogt
#5597
ORIGINAL: Car-Boy
Do you guys know whats a good pipe to use on a Modded 18tz?
#5599
My Feedback: (27)
I made my own just using 4 threaded aluminum spacers...can be got at ace hardware. I planned to use OFNA CD3 mounts, but after i set it up with these i found no reason to change em. Only downside is with as long as the bigblock is, was only able to use 3 screws to hold it to the chassis.
ORIGINAL: momogt
Those threaded spacers are a great idea. I have done several big block conversions to different 1/10 cars and the hardest part is trying to find motor mounts that work. that will make swaps so much easier from now on for me!
BTW: how is the cooling on the engine with the shortened head?
#5600
heat isnt much of a problem...with the tiny tank these things have, and the modded 21, it doesnt run long enough to even try to overheat unless you run it way too lean.
