Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Rock Crawlers
Reload this Page >
losi night crawler rtr vs. bnd???
RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
Old 03-16-2011, 08:44 PM
1cougar1
Default losi night crawler rtr vs. bnd???
looking into the losi night crawler. i have a m11x radio along w/ a few extras 3 channel receivers. could this airtronics system work w/ the bnd. also whats a good steering servo upgrade for it? and i plan on using the stock motor/esc combo for a while but when i upgrade should i go brushless and why/which system is good. xcelorin? last what lipo would i need for it? thanx, 1cougar1
Old 03-18-2011, 02:14 PM
gokemidoro
Default RE: losi night crawler rtr vs. bnd???
Good choice you made. Not sure about the Airtronics working with the stock receiver, as it's a Spektrum, but you could try. Since you have Airtronics receivers, if it doesn't, just install the Airtronics one.
On servos, it's up to you, what brand, but high-torque servos will benefit the Night Crawler. I, myself use HiTec HS 5955's and 7955's, though they are a bit dated by now. HiTec has made faster, stronger ones since then. They are pricey, though, but be prepared to pay for a good high-torque servo, no matter the brand.
In the case of brushless ESC/motor combos, for the Night Crawler, a sensored system is not necessary. Castle makes strong systems for your application. You can call Castle Tech at (913)390-6939. They can point you to a system that will work well for you. They will not try to get you to buy their most expensive system, as other companies would, but if you give them a price range, they will tell you which would be best for the price.
LiPos? That's up to you, but stay away from the "El Cheapo" LiPos. They won't last long. I find Venom and Duratrax are the cheapest LiPos for the best run times and lifespan. Anything cheaper than what they offer won't hold up. Maxamps is a local company, here, where I am, and make high-quality LiPos in just about any size and application out there, but again, they're pretty pricey, but last a looooong time. They are also very consistent, right up to the moment they finally die.
Old 03-19-2011, 09:03 PM
1cougar1
thanx for the info man, 1cougar1
