6x6 Mack
PA
6x6 Mack
It all started with a pile of parts
Custom Mack cab
Custom bed
Semi chassis rails
RC4WD 2spd trans
Axial SCX axles - middle one modified for pass through
4 linked suspension
RC4WD shocks - custom rear rocker for shocks
8 1.9 Tango Down alu beadlock wheels
8 1.9 Trailbuster tires
35T motor
Mamba Max ESC
Then it was a roller
More modifications
I didn't build a shelf queen
Had enough for one day, I'm OUT!!!
Done for now, having fun at a comp after class 2 finished their courses
Still more to do like side tanks, but that is waiting for the full teardown/repaint this winter
Custom Mack cab
Custom bed
Semi chassis rails
RC4WD 2spd trans
4 linked suspension
35T motor
Mamba Max ESC
More modifications
PA
RE: 6x6 Mack
ORIGINAL: nitrosportsandrunner
[X(] <thats what I look like right now.
awsome build man. which I could do that. Never been good at scale builds tho.
Here is the trials truck I am working on right now, just got it rolling under its own power last weekend. My club is looking to organize a trials event this spring and I didn't want to beat the Mack up to much, just needs some finishing touches and sponsor decals
Here is the start of my current "new" build - cab is under the knife right now.
RE: 6x6 Mack
ooohhh 8X8 I've contemplated that before, but I figured the turn radius would royally suck unless you made the front and back steer.
BTW where do you get the cabs, and beds or are they hand made?
PA
RE: 6x6 Mack
Started throwing some steel at it
Now a scratch coat of color to see if I will like it
Maiden run in the foggy wasteland
The rest of the crew that braved the day
