any such thing as scale cowlings?
FL
i would love to build a scale plane that would have a cowl that would be true to scale, in other words be hinged on the side or sides like the real world airplanes are. I hate most cowling attachments that seem once you remove it several times the screws don't hold in the fuse anymore, something like this:
http://www.airliners.net/open.file/0399096/M/
i guess my question is, are there companies that make model cowlings like this? or would i have to cut one and then hinge it?, also how would one go about cutting something like a cowling perfectly straight? the only thing that comes to mind is a bandsaw
My Feedback: (22)
RE: any such thing as scale cowlings?
Its pretty much up to you to build a cowl like that.
However, its not true that regular model cowls screws come loose or only work a few times. If installed properly they will work well for years and years.
I have found that maple is a very hard, hard wood. Using maple blocks is just one way to insure the cowl mounting screw holes will not strip.
Another technique is to install a short piece of the inner Nyrod into the cowl block mounting holes.
Even if you build a scale cowl that is hinged and opens like a real cowl, you will still need to mount the cowl to the airplane. Doh ![X(]
FL
yes true that ill still have to mount it to the airplane, but i was thinking i could epoxy it on, but the other tips are good, - i like the nyrod insert one, that would def. help - the main reason is:
1. it would look cool and very scale
2. everytime i wanted to get to the engine i wouldn't have to pull the spinner and prop off, etc
I would rethink the idea of epoxying the cowl on the plane.
What happens if (when) you need to remove the engine for some reason ? With the cowl epoxied on, at a minimum, it is going to be a "real bear" getting the cowl off AND you can definitely plan on damaging the paint job/covering.
Brian,
You may want to take a look at the following web site. This man is a genius! He is a regular contributor to the rcscalebuilder forum
http://www.mfarchive.modelstuff.co.uk/mf098/wip.htm
Francois
Francois
