Henglong new 1/16 leopard2 is released!!!
#353
You will see when you get it. Look at the turret ring gear and will see the plastic tab that stops the turret. Just remove the gear and cut teeth to match the rest of the gear...its rather simple
#354
Thats ok but be careful that you don't twist the wires off, needs a slip ring or a telephone anti tangle device.
#355
Good day everyone!!! Happy Holidays...
anyway, just before we all go back to work, I figured I'd finish phase 2 testing of the Mato tracks...
so as promised... Mud and Sand...
http://www.youtube.com/watch?v=3v4re1AiQ1k Tracks held up well... although 2 or 3 pads came off(all from the inner track pads - probably due to higher frictional forces on these pads), maybe due to some hard core driving... but performance-wise... these tracks hold up well.
Conclusion... highly recommended.
Its important to use CA glue as suggested and take it easy on tight turns especially on concrete where the resistance against the rubber pads is increased.
#357
Another great video! How are the bearings in the metal wheels holding up?
How are you mounting your camera to the tank? I keep looking for a bracket, but see nothing.
#358
AB, CANADA
Again another great video. I really like the demonstrations you are doing showing this Heng Long tank being put through its paces. I am sure theses videos are contributing to sales!!!!!!
#359
#360
camera mounting... garden ties and 3m mounting tape positioned so they won't be visible on video.
#361
Thanks Captain Nemo12. and yes they do come with spare rubber pads and metal grousers.... you're definitely right, thrown pads are hard to find in the dirt and mud. maybe mato should include more rubber pads.
#362
by the way, do you know how to setup FPV systems for rc tanks? has anyone been doing it already?
#363
AB, CANADA
I added a HK Fat Shark set up in my Sherman with goggles. Camera is mounted in the Commanders Hatch and can pan as it is mounted on a servo, It definitely adds a new perspective.
Right now on ebay there are low cost camera tanks that stream FPV video back to a phone or Ipad. The camera is mounted in the tank barrel and the tank is controlled by your Ipad.
A person could hack one of those apart and fit it into an RC tank, You would end up with a system that had independent control that streams live video back to your Ipad for less then $80. It might be worth looking at.
#365
My Feedback: (182)
I have a couple of questions to ask.
Do I have to always add smoke oil?
it show ABC rather than ON/OFF for what supposed to be smoke function switch. Exactly which position is ON?
How do I open the top of the tank? Just loosen up 4 screws from the bottom?
it appears to have more than that. I just don't want to loosen up something else.
So far, looks good. Still waiting for metal upgrade parts.
#366
AB, CANADA
There are eight screws to take out. They are all lined up.
The smoker is loud enough to hear when it is on. Start up you tank, and then listen for smoker. It has a delayed start of a few seconds after the tank starts.
Yes you have to add oil to the smokers, but not very much. Too much and they will stop functioning. Honestly though it is not a question of if they will quit working, it is just a matter of when
Cheers
Cheers
#367
My Feedback: (182)
Dan,
Thank you for the reply.
I will try the smoke tomorrow. So far, that yellow BB is way too fast to see where it is going. Tried a few shooting with my wife next to me focusing on the kitchen cabinet door we were trying to shoot at. Out of 4 shots, only could see 1 that bounced around.
Junky stock transmitter still works.
#370
I am toying with the idea of switching to a Walkera Devo F7 as a neat and integrated solution for first person view during the Danville battles to check line of sight. One drawback is that they are not compatible with my Spektrum-compatible equipment. Alternatively I could attached a GoPro Hero 3+ with WiFi capabilities and zip tie an iPhone/iPod to the top of my Spektrum DX8.
#371
My Feedback: (182)
What is the largest size motor that I can run on stock plastic gear box? I need a little more speed.
Currently running full stock 2.4 setup out of box.
Metral Track / Sprockets / Idler wheels ordered from Mato should be here tomorrow. Took a little too long. ordered on 28th. Shipped on 1/2 by UPS.
Unless it is really well boxed, I may have a damaged Tiger 1. Way too much delay by UPS saying "Weather problems"
#372
ON, CANADA
Heh, Pattern I work at an airport indirectly with UPS (I'm maintenance with a smaller feeder cargo airline), and let me tell you the weather lately is not plane friendly at all... not to mention in -43C here in southern Ontario, they often don't even let workers load freight.
Anyhoo, any regular 2.3mm shaft can motor won't cause a ton of problems. With the stock gears you might want more torque over RPM. In rough usage the plastic gears won't last indefinitely no matter what you use
I've been slowly converting my lighter tanks over to using these : http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJSS5 They're very fast compare to stock and have the power to back them up.
#373
My Feedback: (182)
Strato50,
I am going to install steel gear box in whenever I get a chance to get road wheels and a few other parts at the same time.
Well, I just got the box from Mato about an hour ago. Typical handling by UPS. crushed corners.
Need to test the Tiger 1. (27MHz with metal gear box, metal track & metal sprockets and idlers).
However, more important thing is missing. I ordered the Mato metal tracks with metal sprockets and idler wheels for the Leopard 2, but metal Sprockets and Idlers are not in the box.
Mato put Tiger metal parts and Leo2 metal tracks in the empty spaces on the back of the styrofoam box of Tiger 1. Tape around with a little bubbler wraps to cover.
Since metal sprockets and idler wheels didn't show, I don't think I will put the Leo2 metal tracks on yet. They sure weigh a lot.
Does anyone know how to get in touch with Mato? So far, I haven't got a reply from 3 different e-mails to them.
#374
ID
Strato50,
#375
My Feedback: (182)
If they do, why don't they tell me what shipped from where?
I do retail business and at any time if something is missing in the order, I contact the customer first before shipping anything.
I don't like to order something that is not in stock just because of unnecessary waiting.
Still waiting for Mato to reply to my e-mails. I will give them the whole weekend to response.
