JP power 480 motors ( ibu 2-Ibu3) video
Quick spin With the JP 480 motors in my Jagdtiger
https://www.youtube.com/watch?v=JQ1MBlXcX_U
Also got a pr of the 400 size will try them out this weekend
So the jp 480 motprs fit right into the motor bracket and they are smaller than the stock motor?
my friend wants to put larger motors in an m41 and speed it up.
Where did you get them?
Rich, to speed up an M41 I'd use the 360 motors from those ebay water pumps. $7 for two motors delivered. Can't beat that, and I've repeatedly demonstrated the speed increase.
the 480 is a tight fit as you can see( silver without markings )
the 400's is the same size as the Stock 380's that the jagd comes With . I bought both, will get the 400 installed this weekend for a test spin .
These are the motors, two for $6.93 and free shipping. You will have to swap the pinion, since these don't come with one.
http://www.ebay.com/itm/2Pcs-Mini-Wa...item3d089120cd
Sollie, is that the Taigen JagdTiger? If so like what you did modifying the upper hull side plates. Great runner withe the 480's thanks for sharing.
Have a look in the New tread I made for the little rebuild I'm working on .
http://www.rcuniverse.com/forum/rc-t...l#post12197495
Thanks will check it out!!!
