Benedini sound
Old 04-13-2018, 09:55 AM
winonagr
Default Benedini sound
Where does one buy a Benedini sound system for a Leo in North America?
Old 04-13-2018, 01:15 PM
tomhugill
From benedini.
Old 04-13-2018, 01:19 PM
Shorty54
Try here,
Aerosound RC Products
or here,
http://www.fieldofarmortanks.com/sound-systems/
Shad
Old 04-13-2018, 03:28 PM
winonagr
Originally Posted by tomhugill
From benedini.
Brilliant. I was looking for a North American dealer
Old 04-13-2018, 05:04 PM
armornut
armornut's Avatar
He is very nice. I've purchased from him a few times, way helpful and super responsive. I live ins CA.
Old 04-13-2018, 05:43 PM
winonagr
Who is?
Old 04-13-2018, 08:16 PM
TheBennyB
There was a North American vendor out of Canada but has since moved on. Far as I know best bet is to order direct.
Old 04-14-2018, 03:52 AM
tomhugill
Better to buy direct from Benedini direct, he will bend over backwards to get the system as you want with the right sounds loaded and setup as you need. He even set mine up for open panzer out the box.
Old 04-14-2018, 03:53 AM
tomhugill
You also get access to the sound library on his site, I'm not sure buying from a third party gets you that.
Old 04-14-2018, 04:50 AM
Shorty54
Make sure you get the programming cable, its worth it in long run.
Shad
Old 04-14-2018, 07:46 AM
Propworn
Propworn's Avatar
This is not Benedini but I found it better. Its made in Canada. You can make your own sound files it comes with the sound editor. Lots of extras for gun flashes sounds of opening and closing of the canopy or landing gear. I have a 6S lipo battery that I run my aircraft at and power the system from the same pack using two 4 inch speakers. He has removed his phone number from his add because of the amount of spam but he responds quite quickly via email
http://modelsoundsinc.com/index.php
Old 04-14-2018, 07:57 AM
armornut
armornut's Avatar
Who is?
http://www.benedini.de/html/home_e.html
the source is who I was talking about.
Old 04-14-2018, 10:06 AM
winonagr
Model Sounds Inc. - The Ultimate in Radio Controlled Model Sound Systems
https://www.youtube.com/watch?v=hQDWP6wMuvw
HaHa thank you for waking my brain. I have that card with airplane files as well as the tank set. I forgot all about that.. I too am using the Open Panzer board with a Sabertooth controller, so its awesome to know they will play together.
Any special hints or settings you recommend?
Old 04-15-2018, 07:56 AM
Propworn
Propworn's Avatar
Each plane has its own micro SD card with the appropriate sound files. Each model has its own speaker system permanently left in. The sound card is held in with Velcro and can be easily transferred from model to model. Electrical connections are a common plug. Each model has a little pocket inside where the micro SD card is stored.
I pick a model to fly while installing batteries I push the SD card into the sound board then place it into the plane and connect the electrics with one plug. Done as fast as putting the lipos in the model.
Each plane has its own micro SD card with the appropriate sound files. Each model has its own speaker system permanently left in. The card is held in with Velcro and can be easily transferred from model to model. Electrical connections are a common plug. Each model has a little pocket inside where the micro SD card is stored.
I pick a model to fly before installing batteries I push the SD card into the sound board then place it into the plane and connect the electrics with one plug. Done as fast as putting the lipos in the model.
Old 04-15-2018, 09:20 AM
Shorty54
I am curious to hear more about this sound unit from Tankers.
Can it be used plug n play with the Open Panzer board?
Does it have the same capabilities to be used in an IR tank?
Are the pre loaded sounds including tank hit sounds, incoming sounds, and destroyed sounds?
Are the sounds and parameters able to be changed by the consumer?
I noticed its similar in price to the TBS Mini after to buy the program cable for the TBS and the Programming software for the Shockwave (39.99USD)
Again its over $220 just for sound.
I am interested, I would just like more input from Tankers.
Shad
Old 04-15-2018, 06:26 PM
winonagr
I will play around with it over the next few days and see what works and what doesn't
Old 03-18-2020, 10:15 AM
Rayan
Hello guys, what do yo think about this product? It seems to be a clone of the Benedini but cheaper.
https://www.ebay.com/itm/DasMikro-TB...r/173971190745
Old 03-18-2020, 05:47 PM
bowlman
That is the Chinese knock off and you can't load sounds from benedini site you have to find your own .
Old 03-19-2020, 09:26 AM
Rayan
Interestin, thank you very much for your information Bowlman!
Old 03-19-2020, 02:47 PM
Pnzjgr
Pnzjgr's Avatar
I've sent two messages to Thomas for information on modifying or adding sound to his sound cards and no response (been almost two weeks). So kind of doubt he's responsive.
All I want to know is can the voice sound of the German Commander from World of Tanks (the older game) be added? Here is what I'm after:
or maybe this one:
This will be for my Taigen Panther F, which I might add I'm putting in Roland's Gearboxes and he is reliable.......
https://www.modellspiegel.com/
I talked to Dominique at rctank.de and he says it is possible on the ELMOD board that the commanders sounds can be added and even sent examples.
Going to put in Clark's TK40 S-Bus after his quick response last night and getting it from his Distributor Kenny (my friend in the DAK club) in Phoenix.
http://www.desertarmor.com/2016/index.html
Edit
I want to update the status of messages I sent to Thomas at Benedini. He responded today letting me know that the sounds/voices I want cannot be added to the sound cards. I appreciate his responding and letting me know it can't be done with the sound system.
I apologize for being critical to him and his business and hope to do future business. The sounds for the Panther are great btw.
Duane
