decisions decisions
Banned
decisions decisions
hey guys got a choice on the next tank (hl) m26 pershing or m41a3 in your opinions which is better
please dont say both or the missus will kill me
RE: decisions decisions
The Bulldog would have the edge in maneuverability, it has higher ground clearance. It has no combat history with American forces, it's tracks are a bit out of scale. The Pershing was the predecessor of the Patton tank series and fought with distinction in the waning days of WW2 and Korea. Other then being slightly more agile, it comes down to personal preference.
SK, CANADA
have to say bulldog for maneuvering. Pershing is good, but i find the out side track drive sprocket catches on everything, and in snow it packs it in there. dunno bout mud/dirt yet.
Maybe it's the electronics, but I find my M-21 maneuvers better and has better speed and soft steering control over the Pershing, which seems to have only stop and full speed. The steering is very jerky, same as my Tiger. The Pershing I converted to M-45 has the same problem, so I think it's the electronics.
Does the Bulldog have a better rc system? My Bulldog doesn't want to fire properly. I can hear the clunk and at first, the ball just dribbled out the gun and then a few shots got out a few feet. The Tiger and Pershing fire well and hit hard. ?????? Also the track-sprocket line-up doesn't seem absolutely correct as the left track wants to pop at one point and it seems the teeth are not engaging right, but so far it hasn't thrown a track. .
Bill
Bill
My Feedback: (24)
ORIGINAL: pattoncommander
Bill your gun may have a broken breech. As for your electronics, do all the tanks have removeable crystals in the transmitter? If yes, then they'd all have the exact same electronics in them. Ohh, I'm getting ready to upgrade the gun on my M41, do you what the correct length of the barrel is? From muzzle brake to mantlet?
The M-41 has replacable chips. Heng long sent me a set when I went thru Ebay arbitration and raised hell about the controller. The other, I don't know as I don't know a transister from a fuse. I'm getting together with some guys in Greensboro next month and will have some expert advice.
Bill
Bill
Does each tanks' controller look the same? On the lower right, is there a switch or a numbered crystal sticking out? That's the difference. I was thinking about removing the outter barrel when I upgrade the airsoft unit, just use the brass barrel and fabricate a new flash hider and muzzle brake. Do you have literature or know how long it should be?
Banned
wow !!! cheers guys my minds made up its gonna be the bulldog liked it when i first seen it.
sorry for not replying to individual posts work took me away from my tanks well i do have to pay for my obsession!!!!!
Good choice! The only problem you will have is that you won't be able to keep yourself from taking it apart and breaking it just so you can start modifying it
Banned
oh my god are we all the same just been examining my 1/35 M41 to see what could be improved on (havent even ordered it yet)
Richard, does the HL transmitter work on the earlier non smoke Pershing and tigers? I'll swing by the museum tomorrow and measure the gun tube. All my controllers look alike except the Bulldog, which has the removable chip which matches with one on the RC board in the tank. The others don't have these. Plus the Bulldog has black movable sliders which do control the movement to some extent. I think these are fine adjustments. On the Pershing and tiger, these do not move. .
To everyone;
terminology; tank gun barrel = gun tube
the blast deflector at the muzle end of the gun tube is a muzzle brake (or blast deflector) and the can behind it is the bore evacuator. (On later tanks, the can is more toward the middle of the tube.) This extracts burning fumes from the large bore of the gun until the loader can chamber another round and seal the breech again. (Breech is the rear end of the gun inside the turret.) Earlier loaders had no eyebrows and face was sunburned from the burning fumes flashing back into the turret. The Pershing had a very heavy double baffle muzzle brake, with two flat areas to kick the muzzle blast to the side. M-26A1 and later models went to a single baffle.
Thanks for the info. I'll look at the sites.
Bill
To everyone;
Bill
My Feedback: (24)
Richard, If I read that right its simply a replacement part, the smoke and sound tanks already have that control. The earlier smoke and sound upgrade kits had this part in them, you had to take apart and upgrade the transmitter as well. Nowadays the upgrade kits come with a complete RTR transmitter.
Looks like Bill has one smoke and sound tank and a couple of the old ones. Bill, for about $28 plus shipping you can purchase electronics just like your Bulldog, this keeps parts common and of course your old 2-speed tanks will drive 10x better! Even if you don't care about the sound or smoke, the driveability improvement alone is worth the upgrade. I've done it to 4 of mine so far.
Big Faux Paux on the nomenclature! Muzzle Break, Bore Evacuator! ARRRGGHH!!!
ORIGINAL: Richard L.
What is a breech and where is it? Do you have a picture? My Bulldog gun is also not firing, and the led on the gun doesn't light up either.
Now, you say you have no lights or motor sound. First open your TX and check for loose wires on the left stick. If not, open the tank, get into the turret and look for a loose wire, its common for the red wire on the negative terminal (it's power- the motor spins backwards) to come loose as its a little short.
That cracked me up " watch the movie patton ".....
try this link benny boy and you will see swathdiver is correct..
http://en.wikipedia.org/wiki/M41_Walker_Bulldog
LA
yea thats a good one ,not to many german tanks left to make movies like patton .so they used what they had .the bulldog
ORIGINAL: Benny Boy
Swathdiver YOU ARE WRONG. The bulldog enter battle with the germans(watch the movie patton)
