JUMBO Build
Old 04-04-2012, 05:39 AM
vett guy
Default RE: JUMBO Build
man some of you guy really do nice work .cought cronic sherman tidis doing my m51.
Old 04-04-2012, 05:00 PM
edoubleaz
edoubleaz's Avatar
I love this tank so I feel the desire to make all the important changes. I am making the Mod on the VVSS metal trucks to incorporate tamiya HVSS springs and tubes. It is tedious work but I like the finished look.
ID:	1746827   Click image for larger version
Old 04-06-2012, 02:41 PM
edoubleaz
edoubleaz's Avatar
Bogies near completion. I am priming everything in Black and OD this time round. Hull tub and trucks done, reattached, and gearboxes reinstalled. One custom mod I have adapted, I use the long speaker box posts to mount the speaker sans box...
ID:	1747517   Click image for larger version
ID:	1747518   Click image for larger version
ID:	1747519   Click image for larger version
ID:	1747520   Click image for larger version
ID:	1747521   Click image for larger version
ID:	1747522   Click image for larger version
ID:	1747523   Click image for larger version
Old 04-06-2012, 04:22 PM
edoubleaz
edoubleaz's Avatar
Work now moves to the charging system and wiring. I add an "m" connector from Radio Shack and give my vehicles the option of charging internally. I mount the double pull/double throw Tamiya On/Off switch from the DMD in a hatch and cut the wire. I solder the wire together on the DMD to close the circuit. My power will be switched directly off the batteries. I usually install the M connector near the power for this process but you could mount it in another hatch.
I color code the tabs to keep the positive and negative sides together.
ID:	1747529   Click image for larger version
ID:	1747530   Click image for larger version
Old 04-08-2012, 04:06 PM
edoubleaz
edoubleaz's Avatar
All my tanks have the power switch throw forward so I connect the rear post on the on/off to the positive post of the "m connector" (red marked part). The middle switch post and a wire from the negative (black) go to the battery so I connect them to a Male deans plug.
The front switch post and a wire to the negative post are soldered to a female deans plug to power the MFU DMD. I build it this way so you can swap them or preform maintenance as needed.
I soldered the red black cables from the MFU/DMD together and ended them in a male deans to finish the wiring plan.
ID:	1748368   Click image for larger version
Old 04-13-2012, 12:20 PM
  #31
edoubleaz
edoubleaz's Avatar
Tank almost back together. Adding standard Sherman details like tools and stowage. This tank will resemble its real life example and lack the rear luggage rack and have minimal stowage items. Latest additions, hatches, mg stowage, welds, and chains to fuel filler caps.
ID:	1749769   Click image for larger version
ID:	1749770   Click image for larger version
ID:	1749771   Click image for larger version
Old 04-13-2012, 01:06 PM
  #32
Ex_Pat_Tanker
Looks good - I'm using this as a bench mark for my build [8D]
Busy bulking up the turret:
and the trans cover:
Still a ways to go before I'm happy tho [&o]
Old 04-16-2012, 04:24 PM
  #33
edoubleaz
edoubleaz's Avatar
I guess you can say I am committed to what I have..... It went into paint this morning....
Black base coat, Olive Drab color coat. I know I usually go into intricate detail on paint techniques, but this time I am using Krylon camo Black and Olive. Why? The real vehicle that I have the privilege of playing with is touched up with those paints. I know, I helped!!!
ID:	1751299   Click image for larger version
ID:	1751300   Click image for larger version
ID:	1751301   Click image for larger version
ID:	1751302   Click image for larger version
ID:	1751303   Click image for larger version
ID:	1751304   Click image for larger version
Old 04-16-2012, 04:42 PM
  #34
Panther F
Panther F's Avatar
Looks gooOood, DAMN that looks good!
~ Jeff
Old 04-16-2012, 07:06 PM
  #35
Rex Ross
The grillwork on the engine deck leaves me speechless. [X(]
Old 04-17-2012, 05:14 AM
  #36
Panther F
Panther F's Avatar
ORIGINAL: Rex Ross
Yeah, what he said and more. The grill work is perfect for a JUMBO ... everyone please take note. That's the correct way it's done.
~ Jeff
Old 04-23-2012, 05:16 PM
  #37
edoubleaz
edoubleaz's Avatar
Well, I have a coat of paint and the markings on. It is marked to match the museum example completely. My paint is a little dark.... time to add some weathering!
Battle debut was disappointing, I have a motor wiring issue to work out.... GRRRRR. Still a crowd favorite and bound to do some damage in the future!
Untitled by edoubleaz, on Flickr
Old 04-23-2012, 05:42 PM
  #38
manchu9inf
Wow, that is nice!! I like it!!
Old 11-05-2012, 04:59 PM
  #39
edoubleaz
edoubleaz's Avatar
My usual coupe de grace, the IPMS Modelzona event in Phoenix. The Jumbo earned a Silver in the armor conversion category, losing out to a pint sized Sherman ironically.
DAK XO Craig Pierce threw out some knowledge with a 1/350 scale LCAC and won best ship!
Member Joseph Garcia placed with an ME-163
Other DAK entries Below.
Old 11-06-2012, 11:53 AM
  #40
wright 971
Hi It always amazes me how one guy with a knife and a bit of glue plus other hand tools can build a better model than Tamiya
Great work Tamiya please take note This Is How you do it
regards pete
Old 03-04-2021, 10:37 AM
  #41
edoubleaz
edoubleaz's Avatar
Well it is time for some Zombie action. This tank has served me well but I confess it throws tracks too often and my best efforts have not kept it running. At the last DAK event I acquired a second hand Taigen Sherman and I have begin a suspension transplant to get it back on the field. The older suspension needs a gearbox replacement to keep the tracks on so it may be recycled down the line!
Simple enough process, I removed the Tamiya innards and upper hull from the legacy Jumbo and cleaned out the Taigen brains, speaker, smoker, and battery box. Only wiring change was to change Taigen connectors to Deans. To make the hull fit I removed 1/8 inch from each side of the Taigen metal and removed the attachment plates and transmission cover. I swapped my old Jumbo trans plate by making some new location holes on the bottom and a few sanding efforts up top. A Motor tool and good file made quick work.
Old 03-04-2021, 06:04 PM
  #42
edoubleaz
edoubleaz's Avatar
Minor update. Made a bracket for the speaker from some plexiglass in the garage. 'Scuse my messy bench.
Old 03-05-2021, 11:27 AM
  #43
RichJohnson
RichJohnson's Avatar
Nice work bringing it back. Taigen chassis really are the best. As I mentioned my metal mato based Jumbo is also in process of moving to a taigen as the mato bogies gave out. Nice you were able to save the jumbo differential housing you made. Mine was tailored to fit the mato chassis and would not transpose to the taigen. My overhaul is just waiting for me to complete my differential housing conversion now.
hope maybe we can have them side by side on the field soon.
Old 03-07-2021, 06:45 PM
  #44
edoubleaz
edoubleaz's Avatar
As the original was for the Museum style look, my refurb will now go tactical... I have decided to add Sommerfield matting, stowage, and weathering. The bars for the Martin came from used sparklers I had in my garage and the matting is some mesh I had from the hardware store. Super glue and paint......
Additional gear came from Value gear. My buddy Steve Munsel hooking me up as usual!
Pnzjgr (03-07-2021)
Old 03-08-2021, 10:52 PM
  #45
edoubleaz
edoubleaz's Avatar
Took the beast on a little road trip and photoshoot.
The following 2 users liked this post by edoubleaz:
Pah co chu puk (03-13-2021), Panther F (03-22-2021)
Old 03-21-2021, 09:05 PM
  #46
edoubleaz
edoubleaz's Avatar
Some more action shots.....
ksoc (03-26-2021)
Old 03-22-2021, 02:01 AM
  #47
Panther F
Panther F's Avatar
Thumbs up
MAN, that is HAWT!!!
Thanks... a great way to start a Monday.
Old 03-23-2021, 10:25 PM
  #48
Michal_Kaczorowski
Second Jumbo build recently and as cool as the other one
Old 03-24-2021, 05:38 PM
  #49
RichJohnson
Actually both of these are old, Ethans here is quite old. Both were just rebuilds and upgrades with better products that were not available when we built our Jumbos originally. Just funny that both of us were rebuilding the same tanks at the same time both with Taigen sherman chassis.
Old 03-24-2021, 10:07 PM
  #50
Michal_Kaczorowski
I wonder why it was changed from Mato? I have only HL and Taigen chassis in my builds but as far I know, Mato is only one with track tensioner. Maybe they will meet someday, you are only 400 miles apart
