monster batteries
monster batteries
my exact setup is a 1717 neu, and a mamba monster esc. 45 tooth spur and either a 15 or 16 pinion, i have been looking into batteries for my setup and would just like to know how to choose ones to match. I was leaning more towards a turnigy nano-tech 5.0 4s, they claim a 45c discharge. do i want such a high discharge? other batt i was looking at was a turnigy 5.0 4s 25c . in the castle manual it says a minimum of 25c. id like 20min run times outa this hopefully
RE: monster batteries
Continuous current = C rating * capacity (mAh) /1000 = Amps
So, a 25C battery can supply (25 * 5000)/1000 or 125 amps. I know for a fact that Mamba Monsters can pull 150A (reference source: beatyourtruck.com)
I wouldn't go any less than a 30C discharge. Also, I would go with 2 x 2S packs over 1 x 4S pack. The packs are cheaper and if the pack dies, you won't be out as much cash. It will make you CRY if you damage, lose a cell or puff a $75-$100 4S. Get some of these-
[link=http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=14980]http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=14980[/link]
I perfer these over the 5000mah packs
http://www.hobbycity.com/hobbyking/s...dProduct=14991
200 more mah, almost $2 cheaper, and in the USA
I use them in most my RC's(they were ran around 40-50 cycles each). My truggy which runs a MM NEU 2200kv combo, and a Savage with a 150A ESC 2000kv motor in it has no issues at all with them. They have yet to get over ambiant temperature actually.
ORIGINAL: SyCo_VeNoM
ORIGINAL: Dale Gribble
Dang! I just bought 4 of the hard case 5000mAh packs! I didn't see the 5200mAh ones that were cheaper. Ah well.
ORIGINAL: redfisher1974
You dont...
You dont...
My 2 hardcases are very slightly puffed. It wasn't due to anything from turnigy, it was due to me storing them at full charge for 2-3 months.
Basically I charged them up one day planned to run the next. Ran the RC for 3 minutes before I broke a part voltage was still at 4.2v a cell, ordered a replacement. Part came 2 weeks later, and after I got the part installed it rained every day I had free time and was off of work for the next 2 months, and days it didn't rain the area was so saturated with water I would have destroyed my electronics if I ran. Now I make sure to drop my lipos to 3.6-3.8v a cell after that, and not had any more swell. There still running, and charging fine though.
It could go unnoticed...
After running them 10-15 cycles since that happened mine returned to normal size, and lay flat again.
