Conection Rod for Team Orion Alpha 21
Hi, a friend has a team orion alpha 21 engine and he want to change bearings and con rod .We found ceramic bearings from TKO and boca bearings but the con rod we cant find it...Who knows where we can find a con rod??or can we put the con rod from a sirio or trinity or werks?thanks
MN
RE: Conection Rod for Team Orion Alpha 21
Yes a rod from a Trinity Extech, Werks B7TL, and the Sirio CL7B will work. Those are all long stroke Sirio motors. DO NOT use a rod from the Sirio EVO line or Werks B3, those are short stroke engines.
thank you very much! but the orion is a 3 port engine (my friend has the alpha series) maybe i must use con rod from B3 engines?like sirio 3port or werks b3?? but i see at the amain shop that the b7 con rod can use it as optional at b3!
