Reload this Page >
Another Ziroli Stuka build
Old 12-04-2014, 01:46 PM
  #101
dalemilam58
outer wing A coming together...port side wing here...if I have my terms right...lol looking at the front port is the right starboard is the left...
ID:	2052203   Click image for larger version
Old 12-05-2014, 08:25 AM
  #102
dalemilam58
half of wing glued ... mocked up with center ...I left the last 2 ribs off for now and the center section isn't glued...I have to wait on the Sierra landing gear...struts and wood block precut before I can glue the center...also I'm using Sig wing joiners so I have to add some shear webbing to the section between the ribs on both wing halves... this was suppose to be a one piece wing, but even with my truck I couldn't transport it...the last picture is a panoramic pic so it is a little distorted
ID:	2052369   Click image for larger version
ID:	2052370   Click image for larger version
Old 12-05-2014, 11:06 AM
  #103
dalemilam58
Laying out both sheets of the plans so I don't build 2 right wings...
Old 12-09-2014, 02:11 PM
  #104
dalemilam58
Figured out the Sig wing joiner(I hope)...added 1/8" ply between ribs 3 to 5 plus I also added 1/32" ply behind the 1/8" this should bring it flush with the other half of the joiner when I add 1/8" shear webs from rib 6 to 8...on rib 4 I had to cut the little tab off at the bottom and will fill in with a scrap piece
ID:	2053435   Click image for larger version
ID:	2053436   Click image for larger version
ID:	2053437   Click image for larger version
ID:	2053438   Click image for larger version
Old 12-11-2014, 07:48 AM
  #105
dalemilam58
I think I need a bigger build table....trying to set ribs 5(center section) and rib 6(outer wing) for Dihedral ...
ID:	2054066   Click image for larger version
Old 12-22-2014, 07:09 PM
  #106
dalemilam58
well I think I figured out the wing joiner...I must have had it slip a fraction when I drilled it...looks like the wing tip is 1/4" higher so I just added a little more dihedral ..
ID:	2057104   Click image for larger version
ID:	2057105   Click image for larger version
ID:	2057106   Click image for larger version
ID:	2057107   Click image for larger version
ID:	2057108   Click image for larger version
ID:	2057109   Click image for larger version
ID:	2057110   Click image for larger version
Old 12-29-2014, 09:18 AM
  #107
dalemilam58
wings finally joined...glad I made it a 3 piece...
ID:	2058703   Click image for larger version
Old 12-29-2014, 06:21 PM
  #108
91zulu
Wow that`s a low ceiling..
Old 12-29-2014, 08:05 PM
  #109
dalemilam58
its only 8'...
Old 01-02-2015, 12:04 PM
  #110
dalemilam58
The big brown truck struck today...now on with the wing build...does anyone remember what size flashlight(torch) was used in the landing light?
ID:	2059894   Click image for larger version
Old 01-02-2015, 12:21 PM
  #111
frank99
My Feedback: (29)
Killer build , all time fav plane
Old 01-09-2015, 11:25 PM
  #112
dalemilam58
Still working on the wing...building a rear wing joiner from 1/2" aluminum channel and bar stock....using it mostly for alignment but might add a screw for strength...
ID:	2062650   Click image for larger version
ID:	2062651   Click image for larger version
ID:	2062652   Click image for larger version
Old 01-12-2015, 03:38 PM
  #113
dalemilam58
a little more progress ...
ID:	2063414   Click image for larger version
Old 01-13-2015, 09:48 AM
  #114
dalemilam58
wings and fuselage together for 1st time..I epoxied the struts into the wing...after doing this I found out that the wheels would be toed out...on side more than the other...I searched and looked to find if the struts could be adjusted, after looking over the setup I found a set screw in the wheel yoke I thought I could loosen it up but when trying the whole strut turned in the block..I got the struts adjusted to a straight ahead mode with no toe in or out...hopefully this was the correct way to adjust them...
Old 01-13-2015, 09:54 AM
  #115
Ed
That sounds good. Be very careful not to insert any toe-in. That only works for automobiles !
Old 01-13-2015, 11:47 AM
  #116
dalemilam58
I'll have more pictures this evening, my son just said my Christmas present just arrived and he'll bring it to me...(for a free supper of course) thanks Ed...will keep the toe in ..out..
Old 01-13-2015, 07:21 PM
  #117
dalemilam58
More parts!!!
Old 01-14-2015, 08:50 AM
  #118
dalemilam58
WOW!...I'm very impressed with http://www.sierragiant.com/ ... I bought a set of struts from them for my Stuka....I was having problems with a toe out condition...I emailed them 2 days ago explaining the problem and asking about adjustments and lack of instructions...well I just received a phone call from Darrell of Sierra ... we had a nice conversation, he explained how they were adjusted and that 3 wood screws are to be used to hold that adjustment...anyway I'm very satisfied with their customer support...
Old 01-14-2015, 12:45 PM
  #119
dalemilam58
does anyone remember about the rudder build...something about it being wrong on the plans?
Old 01-15-2015, 01:19 PM
  #120
dalemilam58
a little more work done...little planer is great...got it at Harbor Freight in a pack of 3 for 10 bucks, needs sharpening right out of the box...
ID:	2063970   Click image for larger version
ID:	2063971   Click image for larger version
Old 07-01-2016, 09:23 PM
  #121
Broken Wings
My Feedback: (20)
Broken Wings's Avatar
Subscribed
Old 12-19-2016, 06:50 PM
  #122
bigbird3
I'm building an 8 foot stuka, can you tell my where to get the pants and canopy?
Thanks, bird
Old 12-20-2016, 07:55 AM
  #123
scoobiemario
My Feedback: (8)
scoobiemario's Avatar
Dale,
How's stuka coming along? I really enjoyed and appreciate your detailed pictures of wing joiners.
I'm gonna start my Stuka very soon. Finishing building table in garage, and need to order sierra gear. Hopefully I'll start this year
