CARF F4U-1 Corsair build thread
Reply
Old 12-23-2018, 07:41 PM
  #3701
David Jackson
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been working on the kit version of this model for the past three months, just curious to know if most builders are using the single servo option for the elevator? Also thinking ahead to paint options, and was wondering if anyone has used latex paints on the Carf Corsair instead of automotive type paints?
David Jackson is offline
Old 12-24-2018, 09:57 AM
  #3702
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used a single JR 8711 servo for the elevator. I used Tamiya spray can paints for the 3 color scheme which I thought were a great match and faded the colors in well, followed by Klass Kote clear satin finish. Mine came in at under the LMA1 limit at 54 lbs wet. I think latex paints will work as well and much cheaper. War Birds colors would work as well as they are latex. If you decide to epoxy clear over them, the latex needs to cure for a month.
LtMash1A is offline
Old 12-24-2018, 07:22 PM
  #3703
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Single servo on the elevator works just fine. The extra servo in the tail requires about 16oz more in the nose to balance. I have used War Bird Colors with good results. Clean the surface well then rough it up. The challenge is on the outer wing panels where the simulated fabric is. Much sanding and you loose the effect. I use a poly clear.
ram3500-RCU is offline
Old 12-25-2018, 02:44 AM
  #3704
flypilot
flypilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi. You seem to have captured the colors for the big hog perfectly, it looks great, any chance you might share your color codes? I know they are called navy blue, intermediate blue and white but there are so many shades available.. thanks again and happy new year..
flypilot is offline
Old 01-13-2019, 06:30 PM
  #3705
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone installed the moki 250 with starter in the cowl of the Corsair? I was curious how it fit.. Rob
rbgetz is offline
Old 01-13-2019, 06:33 PM
  #3706
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a friend doing it this winter. It fits.
Old 01-13-2019, 06:45 PM
  #3707
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure. Here are the color codes.
ANA 606 Semi Gloss Sea Blue
ANA 607 Non-Specular Sea Blue
ANA 608 Intermediate Blue
ANA 601 Insignia White
606 top wings & tail plane & Fuselage sides
607 fuselage top (same as 606 only flat)
608 middle fuselage, rudder, underside outer wing panels
601 under fuselage, tail planes, center section, gear bays
Old 01-15-2019, 10:19 AM
  #3708
flypilot
flypilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ANA 608 s
Thanks...do you have the length of the standoffs for the 250 as well on hand? Or are they the same as for the 215 that was mentioned earlier in this thread?
Thanks.
flypilot is offline
Old 01-15-2019, 10:51 AM
  #3709
David Jackson
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Standoffs mentioned in an earlier post were 7/8", 13/16", and 23/32".
Thank you ram 3500, information you have provided has been extremely helpful.
Old 01-15-2019, 11:18 AM
  #3710
flypilot
flypilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thank you, must have missed that post.. much appreciated
flypilot is offline
Old 01-16-2019, 05:58 PM
  #3711
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks.
Yes I do. They are as follows:
.718"
.812"
.875"
Same for 215/250
Old 01-16-2019, 06:06 PM
  #3712
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
.718"
.812"
.875"
Same for 215/250
These are actual numbers they are machined to. Shortest is the upper port side, middle one is the lower port side.
Old 02-11-2019, 06:47 PM
  #3713
Srobinson352
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An update on our latest Idea. The development of a bolt on baffle system for the Moki, to be independent of the cowl. It will be simply a matter of removing the bolts in the front housing, installing the baffle, and reinstalling the bolts. The first units will fit the 215 and 250. The CAD is done and they are going through the fabrication bidding process. We are getting closer. Once a prototype comes out of manufacture, we will test it on our own 250, and 215. If all is well, full speed ahead. At this point, this is all being done by our fabricating partner. This frees us to concentrate on out other ongoing projects and parts. Should only be a short time to that first test piece.
i would love a follow up on this comment. Did you finish up this project?
Srobinson352 is offline
Old 02-11-2019, 07:56 PM
  #3714
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still in the works. I'll post here when I have something to share.
Thank you for the post.
Old 02-14-2019, 08:21 PM
  #3715
frankyjg2012
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know it has been a while since you posted this, but I would like to know where did you purchase the hinges for the top of the wing small door. I am in the mids of building a CompARF corsair
frankyjg2012 is offline
Old 02-14-2019, 09:11 PM
  #3716
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for stopping Franky. My brother is my "wing man". He builds all the parts and systems related to the wings. I'll check with him on the source of those hinges and post here.
Old 02-15-2019, 12:11 PM
  #3717
jchorak
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Took a cue from txcnguy on the sliding canopy...
jchorak is offline
