P-47 Thunderbolt Brotherhood (All P-47s Welcome)
#1151
Blair,
here is a link to a FlyRC article that I used to solve a similar fuel flow issue.
http://www.flyrc.com/optimize-your-f...t-performance/
Michael
Michael
#1152
Blair,
Michael
Michael
I noticed its a strong performer but occasionally its state of tune would fall off a little. I started looking for clues and noticed an air bubble in the glass bowl on the filter appeared when the tune changed.
My setup is not in that website, i have a 3 line system with a fuel pressure regulator. Ive had it apart twice and changed out the lines and still bubbles. The only thing I haven't changed is the clunk and the brass tubing.
Needless to say im not flying her till i find it as it owes me well over 4k!
Cheers Blair
#1153
Wise des inion my friend. You'll know when it's ready to fly. When you can spend a whole day searching and not come up with a single thing that ain't right. That ain't no 40 size trainer.
#1156
My Feedback: (13)
ON, CANADA
The TF P-47 needs Robart 622 series retracts if you want them to just drop right into place.
see here; http://robart.com/collections/gear-f...-main-retracts
You will notice that the 622's have a main body with the retact leg off to the side.
The retracts in the pic appear look like my 631 series Robarts that are for my H9 30cc P-47.
Dave
Dave
#1161
My Feedback: (49)
Trev those retracts are not the robarts for the topflight TarHeel hal Like I thought but the struts are the proper length 8.75" If U want to use those U will have to make different mounting blocks and line up the center of the retract with the wheel well where the strut goes. Try not to mess up the original mounts so if U get the proper retracts U don't have to redo the original mounts
Treavor ....These are the retracts in my Hanger 9 150 P-47 the strut is the correct length but U will have to use bigger wheels.
#1165
Gents, does anyone have any info on installing Sierra Giant gear / 5" wheels in the TF GS P47 ARF??? I've been Dremeling away on the wing as much as I dare but it seems the gear just don't want to fit. Unlike the stock Robart gear for the ARF, the fork is offset from the strut by about 1/4" on the SG gear. I don't see how the SG gear can be mounted low enough such that the strut and wheel etc are below the top of the wheel well and at least flush with the wing skin. Any help would be greatly appreciated.
#1167
My Feedback: (49)
The reason the stranded 5" wheel Not 6"on the top flight P-47 is not 1-1/2" wide but a little under 1-3/8" wide. 1.365 to be exact. Believe me I know ... Lost the right main wheel on the maiden and had to belly land on the grass. Tried to get a replacement for it. The Wheels are the only thing they don't have as a replacement. But a young lady (that I bugged) finally sent me a complete set of wheels from a complete NIB P-47 that they used as spare parts ... At least that is what she did because it came with a note "to stop bugging them.
#1168
Thanks for the replies. Yeh, what I have concluded is that I will need to use either a narrower tire or go to 4 1/2" wheels instead of the scale SG 5" wheels. The SG gear is great but if it doesn't fit then I will need to improvise somehow. Was just curious how other people had tried to solve the problem. Or maybe use the stock Robart gear if all else fails but that will be my last option (especially since I've already bought the SG gear and wheels).
#1169
Guys make Loctite 222 your friend!!!!
$14 from a screw or industrial shop, specifically for small fine threads you may wish to easily remove.
Use it on everything you value to not fall off.
After the grief you went though finding a replacement wheel would you spend $14 and not have to belly land??????
#1170
My Feedback: (49)
#1171
I have a question for you Blair, When it comes to tank clunks, are you using the felt weighted type? Or the ones similar to the one's heli guys use (not sure if they are the same thing ) I have heard that these types work for eliminating bubbles .
#1172
You must however have a 3rd tube into your tank to fill from and extraction must be done from after the clunk.
Also put a bronze filter in your filler bottle, the more you filter the better. I have one each side of my pump too so the fuel has pasted through 4 filters before it gets to any carby on my planes....I have no engine trouble or dead sticks.
Cheers Blair
#1173
My Feedback: (49)
Personally i prefer the sintered bronze type as they filter well and theres no loose fibres that can cause any issues.
Cheers Blair
Cheers Blair
#1174
any returning fuel has passed through the sintered bronze fuel clunk in the tank so its clean before going back to tank.
The main reason for filters on each side on my filler pump is to ensure nothing leaves those tiny gears and heads up to my plane.
Apart my Saito FG33R3 with enless issues i haven't had a dead stick in hundreds of flights so im not changing my ways☺
#1175
http://www.youtube.com/watch?v=d1-D9UuiLiU&feature=youtu.be
TB
